Whats going on
kyle_252
Hey This Is The System I Plan On Getting Can Someone Check To Make Sure It Will Work Right? Thanks Here Is What They Are. . .
Install Kit
Power Acoustik Complete 4 Gauge Amplifier Wiring Kit ·4 ga. / 20 Ft. Clear Red Power Cable ·4 ga. / 3 Ft. Clear Black Ground Cable ·12 ga. / 33 Ft. Clear Speaker Cable ·17 Ft. Blue Turn On Cable ·17 Ft. Shielded Clear Blue RCA Cable ·AGU Fuse Holder With 60A AGU Fuse ·Complete Accessories ·Double Clamp Blister Packaging
Subs
AudioBahn Dual 10" Tuned Bandpass System 600 Watts RMS
Details:
·High Quality MDF Construction ·Spun Aluminum Venturi Ports ·Durable Gray Carpeting ·½" Plexiglas Window ·Interior Neon Lighting ·Mirrored Interior Panels ·Dual 10" Molded, Texture Injected Poly Cone ·50 oz. Strontium Magnet ·2" 4 Layer ASV Voice Coil ·Extended & Vented Pole Piece ·Gold Binding Post Terminals ·Dimensions: 11.75"(H) x 25.75"(W) x ·13.75"(D)
Amp
Power Acoustik 2-Channel Amplifier 520 Watts Max Details:
·Full Selectable Crossover Hi/Full/Low ·Three Way Protection Circuit ·2ohm Stable Stereo ·Tri-Mode Capable ·2CH 4 Ohm RMS 125 x 2 Ch / 2 Ohm RMS 150 x 2 ·Mono RMS 300 ·Bridged Max 520 ·Full Mosfet Power Supply ·PWM Circuitry ·Variable Low Pass 40Hz-120Hz ·Variable Hi Pass 150Hz-1.5Khz ·18dB Bass Boost @ 40Hz. ·Frequency Response: 10Hz to 30Khz ·S/N Ratio:97 db ·THD: 0.02% ·System Distress Indicator ·High/Low Level inputs With Floating Ground ·4 Gauge Power/Ground Connection ·Gold plated RCA Connectors ·Line output ·Dimensions (WxHxD) 11.25" x 11.25" x 2.25"
Install Kit
Subs
Details:
Amp
Post edited by kyle_252 on
Yeah it will work but Audiobahn and Power Acoustik are flea market brands. You could do 10 times better for the same amount of money.polkaudio sound quality competitor since 2005
yeah, i'd definately avoid those brands... tell us how much you're willing to pay and we can find you some good alternatives in that price range... also look into www.knukonceptz.com for your power wire, they'll be cheaper and just as good!MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
i can get all that for $205 i wanna keep it same range maybe 50 bucksmore but it has to have shipping included so the max i would spend is about $260 -$270
save some cash man... you get what you pay for!
-adamcats.vans.bag... -
dude, i'm gonna be spending that much on wireing LMAO
just wait till you start looking at systems that require you to replace your alternator with one that runs about $700MacLeod: I guess youre lucky Polk has such lax hiring standards.
lolOriginally posted by Joelsbass
yeah...one set of my RCAs were $100...
i might end up having to go with dual alternators...not really something i want to do...
Cody is a baller...Originally posted by exalted512
lol
-Cody
money is no concern to him.
ha...money is DEFINITELY an object...its going to take me at least a year...haha
