Unequal cable lengths in Home Theater
Stan Nuremburg
Stan Nuremburg Posts: 5
edited February 2002 in Technical/Setup
A neurotic audiophile question:
Is it a problem if I use unequal speaker cable lengths in wiring my new 5-speaker surround sound system (Polk RM6000)? I plan to use good 16-gauge, oxygen-free (or so they claim, but at least I don't SEE any oxygen!) made-in-USA speaker cable with gold-plated crimp termination. The shortest cable (left front) would need about 6 feet, the longest (right surround) about 25 or 30 feet or so.
If it IS a problem, how "equal" in length need/should the cables be?
(Ideally, I would use equal cable lengths (my practice in 2-channel), but I don't want to get ridiculous and use 150' of cable in my 11 x 20 listening space/living room!)
Post edited by Stan Nuremburg on
  • scottvamp
    scottvamp Posts: 3,277
    This is a tweeker audiophile concept. As long as you us high quality speaker cable and there isn't huge diff. in runs -like 20' I don't thing there is a sound diff. I MY experience anyway. Don't trouble yourself to much. :)
  • TroyD
    TroyD Posts: 13,124
    In theory, I think the runs to say the L&R rear surrounds should be similar to each other but not neccessarily the same as the L&R front channels....Personally, I say let common sense prevail, run enough to get the job done and not look sloppy.
    Troy
  • goingganzo
    goingganzo Posts: 2,793
    the longet the speaker wire the more restance it has now the most that will do is throw off the center of your sound feild witch you can calabrate. i would post the restance formula but i think that would be a little over the top
  • gidrah
    gidrah Posts: 3,049
    I think the best way would be for the L&R mains and center to be of the same length. The rears should be of the same length as each other.
    example: 3X10 & 2X30
    Adding extra cable to your mains and center to make them the same length as your surrounds would only degrade the signal.
    Make it Funky! :)
