Room Acoustics Suggestions
bobman1235
bobman1235 Posts: 10,822
OK. I probably have the worst room possible for home theater, but it's all I have, so I'm hoping I can get some tips to work with it.
I have a basement "apartment" (cut me some slack, just got outta college :D ). Reasons it's bad acoustically :
1. The room I have my stereo set up in is actually a combo living / dining room with no separation between them, so the left side is wide open.
2. The walls are wood panelling.
3. The floor is tile (I have an area rug in the living room half, where the a/v setup is).
4. Pretty low ceilings (7.5 ft or so).
I've included a pic of the setup below, with the speakers shaded black, and a blue dot where the main "listening position" is. The little circle in the middle of the pic is a lolly column, which kind of precludes moving furniture around.
Anyways, I just finally got a real receiver (HK 525) and expected to be wowed... DVDs sound really good, I'm amazed how much more the rears come out after being calibrated, but music sounds.... glaring and harsh, and anything even moderately loud is very ... fatiguing to my ears, if that makes sense.
So, I guess my questions would be regarding placement (though I don't have much room to work with there) or possibly wall treatment... I have some spare carpet laying around, if I maybe lined the wall behind the speakers does anyone think that would make any kind of difference?
I know a lot of folks around here aren't huge fans of the RTi70's that I have, so I'm hoping the answer isn't "that's just how they sound kid, upgrade or deal with it." Oh, and speakers are connected with 14 guage Home Depot speaker wire. I'm using a Pioneer 578a for DVD and CD listening.
Thanks for any help!
Post edited by bobman1235 on
  • steveinaz
    steveinaz Posts: 19,546
    edited November 2004
    Try these:
    - Bass/Treble is set to flat
    - Less toe-in on the Rti70's
  • bobman1235
    Originally posted by steveinaz
    Try these:
    Yeah, the 70's aren't really toed in that much, I just got sick of using paint and got sloppy :)
    I do have to play with angling tonight though, I was exhausted after re-wiring everything after work yesterday.
  • PolkThug
    PolkThug Posts: 7,532
    Hmmm.... I thought the RTi70'a were the opposite of harsh. Tell us more about your tone controls and are the speakers set to small or large on the receiver, etc.
    Also, could you add where the rug is at, on your diagram?
    Regards,
    PolkThug
  • bobman1235
    Regards,
    PolkThug
    Tone controls were flat, although I did toy around with them a bit with no noticeable effect. I had them set to large... I'll try small although I hate to offload too much sound to the sub-par subwoofer I have.
    The rug basically fills the entire right half of that room... I added a yellow square to show where.
  • bobman1235
    Originally posted by Zero
    That is about all that pops to my mind for the moment. Good luck.
    Pops into your mind eh? :eek: That's fantastic. I appreciate the help! I'll see what I can do on the cheap for now, including repositioning and the like, and certainly look into some room treatment options you suggested. Christmas time is coming :)
    Thanks again!
  • PolkThug
    How big is your TV? I think I've kept my Rti's around 6 feet apart.
  • bobman1235
    It's a 32" inch TV, the stand is probably 3 feet wide. Not too much room to play with there, but I'll try widening it up a bit.
  • bikezappa
    bikezappa Posts: 2,463
    If the stairs are open to the room, I would try reversing the room sonically. Put the sofa next to the stairs and the tv and the main speakers along the wall. You can do this test by just moving the main speakers and listening to music.
    This is a no cost option, just requires moving stuff around.
    Have a blast!
    These modifications will never END!
