Build a 5-channel amp out of plate amps?
Mazeroth
Mazeroth Posts: 1,585
edited November 2004 in Electronics
I have the opportunity to purchase some 100w @8ohm 150w @4ohm full-range plate amps for $32 each with shipping. They're roughly 9 inches x 9 inches. I was thinking of making a wooden box cube with a nice finish, say 12 inches x 12 inches, and mounting 5 of them on the outside, with the bottom solid wood. Put a small surge bar inside and run all the power lines to it, with only 1 power cord running out of it. Put 5 pairs of speaker binding posts on the outside for each channel. This whole project would only cost me about $175 and I would have a 5-channel 100/150w RMS amp with adjustable gains. What do you guys think? Good idea or silly?
Post edited by Mazeroth on
    VR3 Posts: 29,394
    Umm, are they sub amps?
    Dont sub amps have a filter to filter out the highs? :confused:
  • RuSsMaN
    RuSsMaN Posts: 17,986
    If they are full range, why not?
    Cheers,
    Russ
  • hoosier21
    hoosier21 Posts: 4,415
    Not sure but it reads like they are not sub amps.
    It would work , but you may not like the results, plate amps are usually pretty cheap quality. But you never know, might be good enough for you and your use.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Mazeroth
    The guy I know selling them (very honest guy) says they sound great. At full volume there's no feedback and they are an honest 100w @8ohm, and near 150w @4 ohm (he's assuming).
  • hoosier21
    sign me up for 5 then lol
    good luck should be a neat project
  • RuSsMaN
    I'd start with 2, see how they sound. See if he will set 3 more aside for you, for a week or so.
    Cheers,
    Russ
