Go digital or separates?
Mazeroth
Mazeroth Posts: 1,585
edited November 2004 in Electronics
For about $950 I can get a brand new HK DPR2005 digital receiver that has mucho balls and keeps the digital signal digital until it amplifies it. I remember reading a while ago about it doing something like 150x5 at 8 ohms which is just crazy. If anyone has a link to the testing of this unit I'd greatly appreciate it.
The other option is to buy a used but mint Marantz MM9000 amplifier that does 170x5 @8 ohms and is THX Ultra certified (which means it should handle down to 3.2 ohms no problem). I would probably pair it with an HK AVR335 as a pre due to having HK's new room EQ feature built into it. If I really wanted to go 7.1 I'd just use the HKs amp to provide the remaining power, but doubt I'd go 7.1 for a while.
The latter option would run be about $875 so a little change is saved. Which route would you go and why? I currently am building some new speakers so I'm not sure how they'll end up. Probably 88-90db efficient and still undecided on 8 or 4 ohms.
Thanks!
Post edited by Mazeroth on
  • McLoki
    McLoki Posts: 5,231
    I would go separates all the way. You can always update your preamp or get a cheap(er) reciever to act as your preamp, but power is something that once you have, you may not need to upgrade as often.
    When I purchased my AVR, 7.1 was way in the future, as well as variable crossover points. If you purchase a separate amp, you can upgrade your preamp as often as you like and know that the change in sound that you get is from a change in processing. If your amp runs your speakers ok, you never have to wonder if the amp section of an AVR is compatable with your speakers.
    What I am looking forward to prior to my next upgrade......
    Variable crossover points (like every 5hz from 30hz-200hz so I can match them exactly with my speakers.)
    built in high pass filter for the sub output. (variable of course)
    built in Parametric Eq. (high quality and at least 5 bands. I would prefer to be able to have it only impact the channels I want it to. (i.e. have each PEQ channel assignable to any amp group. (sub, front, center, side surround, back surround))
    I am sure all of these things are coming, now that I have an amp that I know runs my speakers, I don't have to worry about that interaction when purchasing an AVR or preamp.
    Michael
  • madmax
    madmax Posts: 12,434
    You can never go too wrong with seperates. And if you do, you can sell one piece and buy another without buying a whole system.
    madmax
    Vinyl, the final frontier...
  • Mazeroth
    Zero, what do you have against both of them?
