bi-wiring a pair of rt2000i's
Systems
Systems Posts: 14,873
edited February 2002 in Technical/Setup
I have a pair of rt2000i's. It looks like I've been hiding under a rock in a cave since I'm technically clutz. Today I asked the folks at polk if I could use a biwire cable with my speakers and they responded that I couldn't. I tought I could since they have two sets of binding post, which I assume is for the hi/mid and one the lows connected by a metal strip. All of your responses make sense, and it seems I can indeed wire my speakers the way you specified. One set to the hi/mid one to the lows at the speaker end and two wires together to the (+) post and two wires together to the (-) post. Am I right with the assumption. Txs.
Ricardo Gonzales
Testing
Testing
Testing
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    Polk is right..you cant..the 1000's and the 2000's you cannot "biwire"...due to this!
    one set of posts are for the subs input...and the other for the mid/tweater..
    that is why...no speration of the mid tweater like on the 800is'.. wich can be seperated.
    hope that help clear things up a bit:rolleyes:
