Memphis Car Audio
audiobliss
audiobliss Posts: 12,518
edited January 2011 in Car Audio & Electronics
Well, I went to an audio store today that I haven't been to in quite a while and checked out what they have in the way of car audio. The first thing I noticed when I went into the 'speaker room' was that they don't have Polk speakers. Next, I noticed they DO have Boston, MTX, ehh, and my memory fails me on the others. However, they also have Memphis speakers. I thought, "Wait a minute; what are these?! I bet they're some cheap things like the MTX speakers, yada yada yada..." However, I listened to the two component sets they had by Memphis, and I like!! I think I'd hafta say they're a little brighter than most that I've heard, but that are not 'bright.' They have good, detailed highs and good bass, from what I heard. I pretty much loved them. Plus, the guy said they'd fit in my '95 Cherokee. So, I think I'm gonna hafta jump on this!!
Has anybody else run into Memphis Car Audio? What all have you heard about them? How do you think they compare?
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • kwade89
    kwade89 Posts: 77
    edited November 2004
    I own Polk/MOMO but I can tell you my best friend has 2 Memphis 10's in a bandpass box in a 01 blazer and they have awesome bass... He dont have memphis highs he has Rockford Fasgate Tweeters and they sound great
    Kaleb Wade
    -00' Chevy Silverado Ext. Cab 1500
    -Polk/MOMO-
    MM6
    MMc650
    MM2124<2
    -Phoenix Gold-
    PG 100.4x
    PG 100.2x
    -Sony-
    Explod HU F7005x
    Explod 10Cd 757mx
  • MacLeod
    MacLeod Posts: 14,358
    Im not a big fan of Memphis. They do make good subs and decent amps but Im not that fond of their speakers. As you mentioned theyre a little on the bright side and while they may sound ok in a soundroom, once they get inside a car with glass everywhere and other harshly reflective surfaces they tend to get tedious to listen to.
    But if you liked them then thats all that mattered. Buy them, install them and God speed.
    Personally though, Id take the MM6 or MMC6500 over them any day.
    VR3 Posts: 29,468
    Since you own Klipsch
    and these are bright, I say get them
  • audiobliss
    Yeah, that's definitely what I'm thinking. Especially since this guy has a $270 set of demo speakers he's sellin' for $170....
    Sounds nice to me. I'll just hafta check the funds & such.
    How long has Memphis been around? Are there amps any good? Should I look at another brand for amps?
    Thanks.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • okiepolkie
    okiepolkie Posts: 2,258
    Memphis Audio has been around for a few years(at least 5). The amps I've heard are pretty good.
    I guess it depends on what you are comparing them to. At the time they were no match for the old Kicker ZR series amps, but they held thier own in many respects.
    Haven't kept up with the car audio seen for a while, but I'm sure someone will point you in the right direction for amplification.
    BTW, what is your budget for the amp?
    Tschüss
    Zach
  • audiobliss
    Eh, well, all of this is just a 'oooh, that's nice; wouldn't mind gettin' that for a Christmas gift', so I really haven't had much of a plan thus for. However, I think I'd rather go with speakers and a HU right now and get the amp later on. If I already had a CD player, I'd say speakers & amp now, but the radio in my car is just that: only a radio. So, I think if I get an Alpine CDA-9831, that would run the Memphis ~ok until I could get an amp.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    ....are they any good? I would eventually get an amp to power my components so I could really hear all the details in my music. Does anybody know if they're amps are any good? How do they compare to JL Audio? Or some other reasonably priced (in other words not Polk!) amps that would do about 75 watts by four? The guy at the audio store said that I'd only need 55 clean watts for any components (well, that I was lookin' at) if I didn't have a sub. Does this sound right? I would probably end up getting some kind of sub in the future. (Probably after my second car; so, a while.) I think it would likely be an 8" in a sealed box; maybe somethin' like 300 watts.
    I remember Hifonics, Orion, MTX Thunder and several others being mentioned before. I don't think I like the Orion amps 'cause their site is no good and I can't find any real specs on them!
    Thanks!!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Joelsbass
    Joelsbass Posts: 637
    Originally posted by audiobliss
    1. How do they compare to JL Audio? Or some other reasonably priced (in other words not Polk!) amps that would do about 75 watts by four?
    2. The guy at the audio store said that I'd only need 55 clean watts for any components (well, that I was lookin' at) if I didn't have a sub.
    1. JL is definately not reasonably priced for what you get....
    2. stick to wattages close to and above the RMS of the speakers, this way you'll have enough headroom to not have to push the amp harder than it needs to be pushed. It's always best to get a fairly close match to RMS values, you're less likely to wind up pushing the setup into clipping that way.
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • audiobliss
    Alright, thanks. So if the components I'm gettin' are rated at 40rms/80peak, should the amp be for 55wpc or 75wpc or 100wpc?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,734
    if theyre rated at 40 then i would say no more than 55 watts per channel...unless you think youre going to upgrade later
    -Cody
  • audiobliss
    Well, I dunno when I'm gonna upgrade. Whenever I get another car, I guess. Who knows when that'll be??? Maybe I should get an amp y'all want so that when I upgrade and need a different one, y'all'll buy it! lol I'll look at some at around 55wpc, then.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    edited January 2011
    reported^^
  • audiobliss
    edited January 2011
    Wow, this was a long time ago! I finally ended up with a Memphis amp, but certainly not any measley peasley 55wpc amp! No, sir! 75x4! I guess I bought that...four years ago? Haha, this thread really is old!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • arun1963
    arun1963 Posts: 1,797
    edited January 2011
    Ringgold and your location in NC ain't too far away.........just saying. Go listen to amazing sound.....
  • Vital
    Vital Posts: 747
    edited January 2011
    audiobliss wrote: »
    :rolleyes:
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
  • concealer404
    concealer404 Posts: 7,440
    edited January 2011
    Vital wrote: »
    :rolleyes:
    Problem?
  • kawizx9r
    kawizx9r Posts: 5,150
    edited January 2011
    Problem?
    He probably likes more 'watts'.
    Everyone's system is different though, as well as their taste.
    I'm very happy with my setup :biggrin:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • concealer404
    edited January 2011
    Heh, like my Punch160 rated at 4x40? :tongue:
  • kawizx9r
    edited January 2011
    My Excelon is only rated at 4x75 :redface:
    Think I'll go tune it some more now, I'm not utilizing the built-in parametric equalizer as much as I should.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • exalted512
    edited January 2011
    Pfft. My radio is rated at 50x4.
    -Cody
  • kawizx9r
    edited January 2011
    exalted512 wrote: »
    -Cody
    SO IS MINE!
    But the built-in amp is turned off though :tongue:
    Kind of wish I got the colored display version of my HU. Meh....
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • audiobliss
    edited January 2011
    kawizx9r wrote: »
    Ding ding ding!
    Everyone's end goal, no matter how you get there!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
