Do I need to fix it?
oregonfan
My kid poked in the center of the speaker. Do I need to fix it or just leave it.
Joe
Joe
Post edited by oregonfan on
Did the dust cap of a woofer get pushed in or was it the dome on a tweeter?
If it is a dust cap, then I won't worry too much about it. If it is the dome on a tweeter, then I might try to undent it.
One way to fix it is to take a piece of adhesive(tape or something similar) and attach it to the dust cap and pull. This would also be good for a tweeter as well.
Hope this helps.Tschüss
Zach -
It's just the dust cover. But now that you mention the tweeter. I have a dome tweeter on my SDA Compact refrence System that is detached. The hair thin wire seems to be still intact. Should I glue it back on and if so what kind of glue?
