LSiC Center Channel
Hello,
i just purchased this center channel and I have a technical question. This speaker has 2 woofers and 1 tweeter. I can hear the sound of the right woofer and the tweeter but not the left one. The left one just vibrate. Is that normal? Is the left woofer just for much lower frequencies.
Please need advice.
Thank you.
Miguel.
Please need advice.
Thank you.
Miguel.
Post edited by mdrivero on
We've covered this one quite a few times recently. May I suggest you do a search for threads regarding the LSiC. You should also do search for Cascade Tapered Driver Array.
That's normal by the way. It's part of the design.
Thank you for the info.
