Quick help needed!
l80241
l80241 Posts: 23
edited November 2004 in Speakers
Ok, Runing LSi7's and LSiC. I need to go with inwalls on the sides and rears.
Would the TCi models match in any way shape of form or should I wait and save up for the LCi in walls to better match the fronts?
I have to move quickly so thanks for your help
Post edited by l80241 on
  • okiepolkie
    okiepolkie Posts: 2,258
    How much are you looking to spend and when do you need them?
    The LC series of inwalls will do better with the LSi's because of the tweeter.
    Tschüss
    Zach
  • l80241
    l80241 Posts: 23
    I was hoping to have things set up by Thanksgiving and want to go with the LCi's, but I can't afford to buy 2 pairs of the Lci's at this time.
    Just wondering if the TCi's would match close enough to make a viable cheaper option so I could get 2 pairs now.
    The rush is a deal that I had on the LCi's just got train wrecked and I need to clear that up today and just wnated to know my options.
