Monster M Or Z Series?
Pinktulip7
Pinktulip7 Posts: 249
Question is Monster M series or Z series,which one is the better biwire speaker cable?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
  • bknauss
    bknauss Posts: 1,441
    edited November 2004
    Choice C... buy speaker cables from a company that produces quality stuff.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Yeah, what he said.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I believe Monster's M-series may be the one they consider to be the higher product line. Lot of mixed opinion here on wire, you might want to consider MIT, I have used both companies and really like the MIT. Still using the Monster on my HT rig and it does the trick. Are you going for music or HT?
    F1nut Posts: 52,165
    We don't always agree, but I'm with you 100% on this one.
    I'll second the MIT suggestion and forget bi-wiring......waste of money.
  • fireshoes
    fireshoes Posts: 3,167
    Yes, M is the higher line, but there is some overlap.
  • dorokusai
    dorokusai Posts: 25,576
    I would try a used umbilical cord from the local Hospital maternity ward. I hear they are excellent.
  • bknauss
    Hell hath frozen over :)
    Brian Knauss
    F1nut Posts: 52,165
    That may be, sure is cold out there tonight!
  • ezc
    ezc Posts: 426
    The Monster M & Z series does overlap & lots of times its the same cable with a different jacket. The Z4 & the M2.2 is the same cable, The Z2 & the M1.4 is the same cable with different jacket & so on. The M2.4 speaker cable dosnt have Z series equal. The M series are ul approved & the Z is not. The Z series may costs slightly less than the M but no ul rating. I use & sell both series. I was told by Monster the Z series was created for BB. Big box retailers cant sell M series so Monster & BB came up with the Z line so they could sell cables = to the M series.
  • dorokusai
    Screw it, edited for content.
  • steveinaz
    steveinaz Posts: 19,546
    Buy some Audioquest Bedrock, 60% off right now at Audio Advisor. http://www.audioadvisor.com
