Lsi7: Recommend Large Or Small Setting?
So what's your recommendation if a person has the following setup...
L/R=Lsi15s
Center=LsiC
Surrounds=Lsi7s
Sub=PSW450
room has small dimensions
power amps to the L/R and center
AVR powering Lsi7 surrounds
sub wired utilizing speaker level L/R inputs from AVR with sub set to off on AVR
Would you recommend in this configuration to set the Lsi7 surrounds to large, or small? AVR crosses over at 80 hz only. I'll probably listen to both but I just wanted everyone's general vote.
Thanks so much in advance for you suggestions.
L/R=Lsi15s
Center=LsiC
Surrounds=Lsi7s
Sub=PSW450
Post edited by jrlouie on
my 2 cents for what it's worth....I have my RTi10s set on large, LFE/Bass output set to Both and crossover at 60. To my noob ear that setup sounds the best for my room.
I would probably set the LSi7s to small.
