equalizer with subwoofer
tgoodley
tgoodley Posts: 13
I have a old AudioControl Model C-22 EQ with subsonic filter and rumble filter. Does anyone know if I can use this with my soon to be built subwoofer. The sub will be powered by an Adcom GFA-555 bridged mono (600w). The sub will be receiving the LFE signal. Thanks in advance.
Tim
Tim
Post edited by tgoodley on
  • PolkThug
    PolkThug Posts: 7,532
    edited November 2004
    If its got an RCA connector in/out, I don't see why not.
    Regards,
    PolkThug
  • RuSsMaN
    RuSsMaN Posts: 17,985
    The subsonic and rumble filters may be very well be useful with a subwoofer application (although there is a greater chance than zero they were designed for turntable use). I'd lean towards using a high(er) end, parametric EQ specifically designed for such application, or nothing at all.
    I would almost think the trade off of having the filters, vs the $.19 resistors the signal has to pass through in your EQ wouldn't be worth it. I'd bet you are going to degrade the signal, more than you are 'fixing' it.
    Cheers,
    Rooster
