Mold on LS50's
eviled72
eviled72 Posts: 2
edited November 2004 in Troubleshooting
I removed my 10 year old LS 50's from storage and they have small mold spots on the rubber surrounding the woofers. I don't want to damage the speakers in order to get rid of the spots. Can I leave it alone or will it spread and get worse? They sound great and have no other damage. I just don't want to do more harm than good. Any help?
Post edited by eviled72 on
    F1nut Posts: 51,703
    There is a product used in hospitals, etc. for removing mold, but first I would try Windex. Spray it on a soft 100% cotton cloth, then wipe gently in a circular motion. If that doesn't work I'll get the name of the other stuff for you.
  • Tour2ma
    Tour2ma Posts: 10,177
    I'd give hydrogen peroxide a shot... Very mild disinfectant... that won't attack the rubber...
    Be careful of drips "bleaching" out fabrics in the neighborhood...
    H2O2 is the stuff blondes are made of... :D
    More later,
    Tour...
    Vox Copuli
  • eviled72
    eviled72 Posts: 2
    Thanks for the info. I'll try hydrogen peroxide and then windex.
