Just hooked up my Tempest and I'm a little disappointed
Codey
It's not really that loud or deep. Will it sound significantly better after break in ? Or am I just not feeding it enough with my adcom 545 II ?
P.S. It's an adire alignment
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
Post edited by Codey on
The Adcom is doing fine until those LEDs light up...
Once those LEDs light up, ur taxing it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
pretty complicated question and very little info..
Are you sure of the wiring? both channels wired? both VCs wired in phase? How are you feeding the Adcom? y splitters, what crossover? Are you sure you have the correct mass on both PRs? How air tight is your box/drivers? Is this subwoofer sitting where you last subwoofer sounded best? have you tried moving it?
That subwoofer is a beast! I built it myself a couple years ago, you might be using up that Adcom, but the driver is very sens. so maybe it's not the problem. I know I made the mistake of getting a 250.00 plate amp from Partsexpress, I felt like the amp did not have the juice to push all that mass (PR's) and the Tempest.
RussDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Sounds like u may have a possibly air leak?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Here is my chance to learn something, Sid, what is it in his post that leads you to that?Dodd - Battery Preamp
The wiring is right, I'm using a y jack with the crossover set to 160hz. I followed the plans to the letter and I'm POSITIVE there's no air leak.
It's sitting where my old one was, and moving it around isn't an option for obvious reasons.
I've been running it a while now and it seems to be sounding better, but far from my expectations.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Get some real deep stuff, music or test tones and play the crap out of it, see if there is any improvement each day it should loosen up.
What about those PR's, weighted correctly?Dodd - Battery Preamp
What's a PR ?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Passive Radiators, didn't you say you were using the Adire Alignment? you should have two passive radiators, right?Dodd - Battery Preamp
No it's vented. It's the last one in vented section of adire's website.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Well,
I have very little knowledge of this...
But a woofers volume comes from trapping the back wave inside the enclosure (right?) - this is why a woofer has NO volume outside of an enclosure except a few higher frequencies...
Well if the back wave (air) isnt being kept inside the enclosure, etc -- and is leaking out, this can cause it to lose volume, no?
(Willing to be corrected if wrong, which I probally am)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well **** that's a different animal.
Adire calls more than one design the "Adire Alignment" my bad I thought you made the one like I did using a pair of PR's.
Break that bad boy in and let us know how it's going in a day or two.
Hey sid kid,
Guitar speakers are routinely placed in open back cabinets.
They produce plenty of deep bass.
Your theory is flawed.
Nice try though. -
That is like a baffle design though, isnt it?
Where the back wave/front wave travels along the baffle, the baffle thus replaces the enclosure
Polk Audio uses this in their Car Audio department to replace enclosures...
Oh wait, I have seen what you are talking about....
No idea, all I know is, subwoofers are made to be air tight, when design inside an enclosure where it is *sealed* or vented, the vent is made to release air, not other portions
And, please dont post "Your Wrong" then go away, EXPLAIN...:rolleyes: - I'm here to LEARN :cool:- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I have a good example...
My Black Labs I am making...
These use a labyrinth design - the design is pretty basic, the polyfill absorbs the midrange back wave so it isnt audible in the port/opening...
However, the bass backwave makes it past the polyfill and exits out the large port, thus amplifying the bass...
The bass has to successfully pass through this long port, and has to become compressed as each fold gets smaller or it wont sound right...
The open back guitar is a different design, it is designed to be open back...something that is NOT design to be open back aint gonna work like that...
If you make a subwoofer that is ported and then leave a panel off, its gonna sound funky and not to mention the port would be pretty useless...
How about a sealed bookshelf, would you just take a panel off of that?
I just want an explanation other than your wrong man...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Codey,
Did you put a caulk ring around the port and woofer?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good advice from Hoosier. That sub goes very loud and very low. Like 115 dB easy with 250W. It does not sound significantly different when you break it in IMO. Maybe you are only powering one coil (maybe a wire came loose) or maybe the Adcom isn't putting out the power. Are you sure the port lengths are correct? Can you measure the DC resistance of each coil? Just throwing out suggestions.
Because the Tempest is tuned in the teens and most subs are tuned in the 30-35 Hz range it will sound very different. Maybe you just have to get used to the sound.Graham -
Thanks for all the help everyone.
I've caulked everything, and I'm sure both coils are wired correctly. I'm in the middle of watching The Day After Tomorrow, and I think I'm starting to warm up it. It sounds alot different watching movies than it does listening to music.
I'll break it in real good and if I'm still not happy maybe I'll look for a bigger amp.Thanks again.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Put your hand under the sub, when it's cooking you will feel the driver move a lot. It should move like 1/2" each way when it is cranked.Graham
I think you are underpowering the 15" Tempest. Try an amp with 300-400 watts continuous and I think you'll get to where you want to be.
Regards,
PolkThug -
yes more power a nice pro amp and also get a bass sweep cd to run a sweep i also have to crank up my sub for music to sound right
How about one of those crown xls-402s ? They seem like an awful lot of amp for the money.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
That's about my price range. I don't know of anything else that fits these requirements.
If I got a bridgeable amp like a NAD 2200 or something, could I run the voice coils in parallel ?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
So does this mean that Sid was correct? It's "possibly", isn't it?Originally posted by Codey
... it's vented.
We can give him partial credit and still flunk him for poor grammar...More later,
Tour...
Vox Copuli
Then to be precise I have two 3 inch diameter air leaks.
I had a 202 before this one. I wasn't really expecting an emphasized boom, it's just that the way people take about this thing I expected to be knocking stuff off the walls. And when it feels like it's going to really start shaking down low, those stupid distortion lights on the amp come on like highbeams.
Maybe I'll try to get this thing. Any thoughts?http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&category=71543&item=5728327904&rd=1
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Yeah, the Adcom has quite a bit of power...
But not enough to power the low end on a subwoofer..
Hopefully you find a suitable amp...
Parts Express has a 260 dollar plate amp on blow out, 106 dollars - maybe that will do something for you?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Depending on the tuning point of the enclosure, the woofer will not "see" those vents as air leaks. In this respect it will act similarly to a sealed subwoofer until near the tuning frequency.
At/near the tuning frequency, the vents (Helmholtz resonators) will damp woofer motion and shoulder most of the output load.
Below the tuning frequency, the woofer will then "see" the vents as actual air leaks and woofer motion will be poorly damped. Bottoming the woofer is easier below the tune point for this reason. Thus the use of the high pass filter to ramp down the response below the tune point; it protects the woofs........."What we do in life echoes in eternity"
SVS -
More later,
Tour...
Vox Copuli
You guys get on my nerves sometimes...
And the fact what I was talking about above is COMMON AUDIO KNOWLEDGE is even MORE ANNOYING.
1) If you/or a company make a speaker, DESIGNED!!!!!!!!!!! To be SEALED OR PORTED then it is TUNED to a frequency, either by port size/depth or cabinet volume!
If even the SMALLEST air leak is evident in that given cabinet DESIGNED for a SEALED (COMPRESSION CHAMBER ANYONE?) or for a PORT, it will throw EVERYTHING off inside that cabinet, volume, extention, EVERYTHING.
Who in the hell cares about open back guitar amps? I am not even talking about that DESIGN, which open back guitar amps with open backs were designed for open back.
With YOUR theory, it is apparent that you believe that if I were to remove the top or side of one of my speakers that they would sound the same, regardless...
Now, I am about 99.99% sure I am right about the above information, and throwing BS comments about open back guitar amps and a vent being an air leak is lame...
:mad: :mad: :mad:
*Looks around for someone willing to explain to why Im wrong or how hes right, instead of this...is someone afraid to have an intelligent conversation around here or something?*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Without question, a leak in a vented enclosure will degrade performance.
For example, pull the baseplate on an SVS PB12-ISD and it will piss air out all the t-nut holes. The enclosure won't be able to generate as much internal pressure and the sub won't perform properly.
So - air leaks are not the same as a tuned vent. And air leaks are bad in any vented or sealed subwoofer.
BTW, Sid - sealed subwoofers are not "tuned" to any frequency. Although the -3 dB point can be modeled with a combination of enclosure volume and T/S parameters, etc.
Tour, looks like that thread is in good hands (Ron Stimpson)."What we do in life echoes in eternity"
SVS
