Who's done DIY Magnetically shielding?
NuckingFuts
NuckingFuts Posts: 77
edited November 2004 in Speakers
Im wondering if any of you have done your own magnetic shielding on your speakers?
If so what did you use and what were the results?
I found this stuff but not sure if it will work or if its safe for my speakers:
http://www.lessemf.com/mag-shld.html#274
Post edited by NuckingFuts on
    VR3 Posts: 29,435
    edited October 2004
  • brettw22
    brettw22 Posts: 7,623
    edited October 2004
    Sid, your link is no good........
  • gatemplin
    gatemplin Posts: 1,595
    edited October 2004
    You can buy a bucking magnet but I've never tried it.
    Graham
    VR3 Posts: 29,435
    edited October 2004
    Go to...
    www.partsexpress.com
    go to their search bar, type in - Bucking Magnet
  • sowen010599
    sowen010599 Posts: 343
    edited October 2004
    I've done it. Just cleaned up the back of the speaker and the magnet with some alcohol. Then I attached the bucking mag. with some 5 minute epoxy from the local Hobby Town. Works good.
    Go BIG or go home!
    F1nut Posts: 51,786
    edited October 2004
    Bucking magnets are what speaker companies use, they are cheap and easy to install using 5 minute epoxy. Don't forget to do the tweeters.
  • NuckingFuts
    edited October 2004
    What size did you use for the 6" and tweeters?
    F1nut Posts: 51,786
    edited October 2004
    "As a general rule, the bucking magnet should be approximately 1/2 to 2/3 the size of the driver magnet."
    I got mine from Polk. If your doing the LS90's call Ken and tell him what you need and he'll set you up.
  • nadams
    nadams Posts: 5,877
    Why would speaker manufacturers not do this from the factory? The bucking magnets are so cheap, it would add only a negligable amount of money to the final price.... does this effect the performance of the speaker at all?
    Ludicrous gibs!
    F1nut Posts: 51,786
    These days a lot of them do, especially speakers aimed at HT use. The bucking magnets do change the Q of the driver, but not that you would notice.
  • Tour2ma
    Tour2ma Posts: 10,177
    Yup and drop the sensitivity 0.5 to 1 dB... not significant...
    nadams,
    Once upon a time there was something called Stereo... ;)
    Either Uncle Jesse or I can finish the story sometime...
    More later,
    Tour...
    Vox Copuli
    F1nut Posts: 51,786
    Ok, but he isn't sitting on my lap!
  • Tour2ma
    Damn right he's not... that's my territory... :D
    More later,
    Tour...
    Vox Copuli
  • nadams
    nadams Posts: 5,877
    Uhhhh.....
    eww?
    Hey, I know all about stereo.... do you see any HT in my showcase? :-)
    However, my monitor 10's do weird things to my CRT monitor in my room, depending on how close it is. But I'm not going to go the bucking route anyway, just curious...
    Ludicrous gibs!
