Looking for a amp
kyle_252
kyle_252 Posts: 47
edited October 2004 in Car Audio & Electronics
k so my budget is $400 i can do the install myself, the subs im getting already are in the box, and its a cost of $130, i need wires and an amp so if you dont mind helpin me out ill give you the link to the sub i have in mind. Thanks so much
http://www.bestbuy.com/site/olspage...81&type=product
Kyle
Post edited by kyle_252 on
  • neomagus00
    neomagus00 Posts: 3,899
    edited October 2004
    the link doesn't work, what sub is it?
  • kyle_252
    kyle_252 Posts: 47
    edited October 2004
    The Sub is a dual Two 1100W 12" single-band-pass Subwoofers with box-black , Model: XINBP212. if that doesnt help you what are you looking for?
    Kyle
    Lets try it again just incase
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2004
    I cant tell if its set up for a 4 ohm mono or 2 ohm mono load. Ill assume a 4 ohm load in which case you should check out this MTX Thunder502. Its built like a tank and puts out much more than its 500 watt rating.
    There is also this Crossfire VR602 which, like the MTX, makes way more than its rated and is very well built.
