Polk db690 : midrange/tweeter question
bluzrip
bluzrip Posts: 93
edited October 2004 in Car Audio & Electronics
I just received a new pair of db690's. One of them has a loose midrange/tweeter module on the post. Rotating it slightly (about 30 degrees) snugged it up. But now it is out of line with the bass cone which may contact it in large excursions. Is there any way to adjust this?
"You can tell by the kindness of a dog how a human should be." Don Van Vliet
Post edited by bluzrip on
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited October 2004
    Peel off the sticker half-way on the back, or poke a hole through the middle. Turn the bolt clockwise to tighten the post. These are usually bolted in, and will usually be epoxied where they cannot come loose. You say 'new' maybe a return would be in order? No sense in **** up the warranty if you've got one.
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
