3 or 5
gwh
Ive changed all my speakers from RTIs(8ohm) to lSIs(4ohm).
LSI7-front
LSIC-center
LSIFX-surrond
Denon-3803
Im considering buying a three-channel amp for the fronts and run the surrounds off the Denon,
any obvious drawbacks to this idea? I figure this would take a lot of the load off the Denon , and I could probably pick up a three channel for less $ than a five.
System used for HT, and music in stereo or prologic.
G
LSI7-front
LSIC-center
LSIFX-surrond
Denon-3803
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
I would believe that 3 would be more than fine. Give your situation that's what I would do. Actually I'd probably go with a number of stereo amps and use accordingly (left front & right surround, center & rear, etc).Make it Funky!
Only drawback I see is leaving three Denon ch's behind....
Try three and bi-amp your front stage with the Denon and the outboard amp...
An amp is a terrible thing to waste...
Is there a sub in this picture?More later,
Tour...
Vox Copuli
