Outlaw combo 950/770 w/RTi12
larryp123
larryp123 Posts: 9
edited November 2004 in Electronics
The forum keeps suggesting the more power the better to drive the RTi12's currently using a Denon 3805 (Note: Will move the 3805 to drive in wall living room system).
Setup:
RTi12 front/main
RC85i surround
CSi5 center
PSW505 sub
media room 20(l)x15(w)
6.1 home theatre w/above speakers....
90% movies and music dvd's
10% 2-channel audio
Forum's thoughts on Outlaw 950/770 or comparable set up in the same price range - around $2600?
Will moving from 120wpc to 200 wpc make a significant difference at moderate volumes?
Thanks,
Post edited by larryp123 on
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2004
    Your significant increase will be in headroom, or peak watts. I think an upgrade from 120w to 200w is probably worthy of the expense.
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2004
    You could do it a step at a time and get the amp now and the 950 later. If the 770 doesn't suit your needs you've got 30 days to return it.
  • HBombToo
    HBombToo Posts: 5,256
    edited October 2004
    True and agreed but the 770 has all one could hope for....:D
    HBomb
    ***WAREMTAE***
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Originally posted by larryp123
    RTi12 front/main
    RC85i surround
    CSi5 center
    PSW505 sub
    I'm missing something here... What's your rear center? A 3rd RC85i or a 2nd CSi5? And what is an RC85i?
    Agree with the above, no reason to ditch your Denon as it makes a fine PrePro...
    Would point out that a more modest 2 ch amp could be employed to bi-amp your 12's along side the Denon. Or a 3 ch to bi-amp your front three.
    Doc Spec runs three Outlaw mono-blocks for his front stage off a 3805. The surrounds, set to small, just don't get busy enough to demand as much power.
    As for noticing a difference at modest listening levels? Good question that depends on our relative definitions of "modest".
    If in the 70 dB-ish range... no, I doubt it.
    If in the 80-ish... possibly.
    In the 90's... Oh Yeah...
    Biggest difference of all will be noticed during the 10% time... Mains to large, sub off... double the power to the 12's with current to spare... Oh yes, the difference will be evident.
    Welcome to the Forum, Larry...
    More later,
    Tour...
    Vox Copuli
  • larryp123
    larryp123 Posts: 9
    edited October 2004
    The RC85i are Polk in-wall speakers. My media room was pre-wired for 6.1 surround. I am also using the same speaker for the rear center.
    The reason I am looking to upgrade is that my living room was also pre-wired for 5.1 surround sound and I'm going to have Polk 4 ea. RC80i in ceiling speakers installed. I figured if I have to buy a new receiver/amp. for that system, I may as well move the Denon to the living room and upgrade in the media room.
    As I was doing my online research, it appeared you get a lot of bang (power) for the buck with Outlaw products. I am not familiar with Outlaw and was wondering if anyone had any experience with Outlaw driving Polk speakers.
    I'm up for suggestions on other components as well... I just want to stay under $3000.00 for the pre-amp/amp or reciever.
  • Frank Z
    edited October 2004
    I've been using an Outlaw 7100 for over a year to drive my Lsi's. Great product and a great price. There are a few Polkies using Outlaw gear. Try using the search feature, you'll find a lot of threads on this subject.
  • Tour2ma
    edited October 2004
    Not arguing against new Outlaw gear, but with an "under $3000" budget, there are numerous used options, if you are open to used. Field slims some for a 6.1 rig, but there are options...
    More later,
    Tour...
    Vox Copuli
  • larryp123
    larryp123 Posts: 9
    edited October 2004
    I am definitely open to "B-stock" or factory refurbished. Would like some type of warranty even if it’s 90 days to a year.
    Any suggestions on product would be appreciated....
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2004
    Tour2ma,
    I thinking about doing the same thing with a 770 amp but with an Onkyo for the PrePro. With 7 channels with the 770 amp why not just bi-amp the fronts from this amp? This leaves 3 channels for center and rear surrounds. Right what are you thinking or what I'm I missing?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2004
    Welcome Larry!
    I agree with the others that the mains and center need the most headroom. I would also like to throw in a thought in that the Denon 3805 may be a better preamp than the 950. You have alot more control over processing, crossovers, upconversion of video, etc. The weakest part of the 3805 package is the 7 channels of amplification. They aren't weak in and of themselves, they just aren't as top shelf as the rest of the electronics. You do actually have plenty of power for the inwalls as you are today.
    I would keep the Denon, purchase enough monoblocks to get the front soundstage way ahead of its current state and then have $$$ to play with later, when HD DVD is available or a projector is needed.
    Then again, if a rack of matching units is important, go Outlaw throughout.
    Cheers,
    Dennis
  • Tour2ma
    Dennis,
    Since you more or less agree with me, allow me to tell you how wise you truly are...
    Steve,
    No reason not to do as you suggest. Upon return of Sunfire #2 (in route per Mr. Dion), four of my ten Sunfire channels will go to my SRS mains...
    Only small issue I have with dropping outboard amps on an AVR (besides the dents... :) ) is leaving any power on the shelf, as in unused AVR channels.
    A watt is a terrible thing to waste...
    If your Onk's channels are reassignable, then you have many options to avoid this embarassing situation...
    One other consideration... keeping the same amp on the front trio, or at least on the halves of the front trio*, helps insure seamless blending. There are differences in amps' "sound", even different amps from the same Mfg. Granted amp differences will not be as great as different tweeters, but there are differences.
    I am actually a little surprised that as much bi-amping that has been done with amps from differnet Mfg's that no one has commented on/ been displeased by this... May be as simple an explanation that it's not as critical in HT aplications as in 2 ch...
    Oh boy.... my 1st footnote...
    * - in "halves of front trio" I mean one Mfg amp on the tweetes and another on the MW's, e.g., assigning your Onk to the tweets and the Outlaw to the MW's...
    More later,
    Tour...
    Vox Copuli
  • RVJII
    RVJII Posts: 167
    So you wouldn't recommend using the Onkyo for the mids/tweets and the Outlaw mono blocks for the woofers?
    A lack of planning on your part does not constitute an emergency on my part...
  • Tour2ma
    No, I'd say that has a very good shot at being very satisfying...
    What I would be less enthusiastic about doing is bi-amping only the mains as you described and leave the center solely on the Onkyo... But again several have done this using various combo's of AVR's and 2 ch amps, and liked the results...
    More later,
    Tour...
    Vox Copuli
  • Dennis Gardner
    Tour,
    Timbre matching of different types of speakers (MTM centers, bookshelves or towers for mains and bi\dipoles for surrounds)make the amplification portion a secondary concern.
    I agree that the mixing of amps has always been an issue in 2 channel. The sheer number of channels HT now has and the $$$ needed to biamp with quality components have many shortcutting normal practices.
    I do think that the nature of HT is more forgiving, even though I really like accuracy in all reproduction of sound. Rarely are the same sounds coming from all channels at the same time.
    I see biamping in an HT at a midlevel investment as a waste of $$$. Room treatments, better source, processing, and upgraded speakers come to mind as a better value to me. But then again, wouldn't 2 Outlaw 770s biamped into 14 channels be killer??!!
    Cheers,
    DG
  • Tour2ma
    LOL... More like "overkiller", I'd say... but :cool: ...
    Dennis,
    Agree that speakers dominate the equation, but given that many have matched at least their front stage I still find the absence of amp matching issues surprising. HT is demanding enough, again at least in the front stage, to show differences.
    I can certainly chalk it up to the lack of a basis of comparison. Before the 3.1tl's arrived I thought my CS400 blended nicely with my SRS's, but the tl's blended better during their stint. Now I'm back on the SRS's and the blend seems fine again... Fleeting audio memory is the only reason I can give...
    More later,
    Tour...
    Vox Copuli
  • RVJII
    RVJII Posts: 167
    Tour2ma...
    I have matched my front soundstage. (RTi12's and CSi5) So if I were to go with 3 mono blocks you think that it would work ok? Just to be clear, the result would be 110wpc (Onkyo) to the mids/tweets to the L/C/R and 200 wpc (Outlaw) to the woofers on all three.
    Thanks for you help...
  • Tour2ma
    Sounds like a plan to me...
    More later,
    Tour...
    Vox Copuli
  • disneyjoe7
    Bruce,
    >>If your Onk's channels are reassignable, then you have many options to avoid this embarassing situation...<<
    Huh?
    >>One other consideration... keeping the same amp on the front trio, or at least on the halves of the front trio*, helps insure seamless blending.<<
    Will that is what I do now my Onk those the front trio speakers on the upper halves R & L speakers. A HK amp is used the the lower halves for the R & L speakers. A seven channel amp will just keep the front trio has the same while balancing the whole HT speakers, and giving me more watts for the front speakers in 2 channel music. Using those power hungy RT150i for R & L speakers.
    >>May be as simple an explanation that it's not as critical in HT aplications as in 2 ch...<<
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Mike Reeter
    Mike Reeter Posts: 4,315
    RVJII,I also have a pair of 12's and the CSi5 up front...I'm also looking at hooking up some "real" power for those 12's...
    I'm leaning toward a Rotel RB-1080 (2x200) to power the lows and bi-amp with our Denon for the highs,maybe later on picking up a Rotel RB-1075 (5x120) to bi-amp the upper end of the 12's plus the CSi5 and side surrounds...
    I like to listen to 2-channel music also,plus have the power for HT,I would be very interested in what you decide to run with,please let us know what you come up with and how the "sound" turns out for you.
    Thanks,Mike
  • Tour2ma
    The "huh" statement was just around the waste of amplification that results when you turn AVR's into Pre-Pros. It's a personal affliction...
    More later,
    Tour...
    Vox Copuli
  • disneyjoe7
    So it won't harm my AVR? Is just a waste of it right?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Tour2ma
    Hurt its feelings...maybe. Otherwise... no.
    More later,
    Tour...
    Vox Copuli
  • Shell
    Shell Posts: 134
    Larry I got an Outlaw 7100 B-stock that I love. They are currently running B-stock items with free delivery. You get the full 5-year warranty I believe.
  • malikarshad
    malikarshad Posts: 527
    I'm running an b-stock Outlaw 770 with Denon 3803 as a pre/pro for my HT and absolutely luv it. Outlaw products are great for the price/performance ratio.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • Sami
    Sami Posts: 4,634
    When you only use external amps for the mains (or front three) and use the AVR for surround, you're not wasting much. Isn't the major concern on AVR's their powersupply? If those 2-3 channels are going unused it frees up the PS for the surrounds, giving them more current that they would have available if the front would be amplified by internal amps.
    Right?
  • Tour2ma
    Interesting question....
    Certainly given the higher 2 ch power ratings you almost always see in AVR spec's, you'd suspect the power supply/ transformer is the limiting component in their design.
    Haven't seen spec's showing that the surround channels increase their output if the center and/ or mains are idled, but assuming the same amp circuits are in play (and no reason I can think of that they would not be the same), it makes sense that their output would rise as well...
    Thanks, I feel far less afflicted now... :)
    More later,
    Tour...
    Vox Copuli
  • disneyjoe7
    Interesting question indeed. If I was to add a 7 channel amp 200W x 7 so my 5.1 HT setup will drive my RTi150's bi-amp'd all other speakers are feed the same amp so all voices should be the same. If I then Bi-amp my rears with the AVR outputs feeding the upper or lower, the AVR being 110w (maybe) the AMP being 200w then wouldn't the voices be off if feeding the upper or the bass off because it feeds the bottom. Speakers in question are the RT800i for rear surrounds.
    I thinking YES it best the WASTE an amp ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sami
    Sami Posts: 4,634
    You would need to measure the output on those preouts and use the amps controls to set correct gain.
    http://sound.westhost.com/bi-amp.htm#4.1%20-%20Measuring%20Amplifier
  • Tour2ma
    Yep calibration at least sets an equal baseline.
    SS amps have different gain ratios, slew rates, etc. A single point calibration does not address these differences, other than at that single point. So in a dynamic situation the differences might be heard, if the amp characteristics are different enough.
    Given the choice between the same amp all the way around, and mixing and matching, I'm sure most , if not all, would choose the same. But sometimes $$$ is a factor and mixing amps, at least as a stage in developing a system, is necessary. Many here are in that very stage and enjoy their systems just fine. Some so much, that they stay there a long time...
    Steve,
    I think power differences you cite would be lower on the list. Especially if a sub is in the mix and the "5" are set to small, I would think running out of power to surrounds being bi-amped with 100 wpc times 2, is not very likely. I do see issues with the center channel to be more likely.
    The other question would be: Don't your 150's and 800's already have a different voice?
    More later,
    Tour...
    Vox Copuli
  • disneyjoe7
    Steve,
    Bruce,
    Yes my Rt800i vs my RTi150's have different sound / voices, but I don't really hear that difference due to them being used as surrounds. My CS400i vs the RTi150's sound different, but again not that large of a change for me to pick up during a movie.
    My biggest fear is this I wish to up the Wattage to my RTi150's by bi-amping them with a 7x200w amp. So the front RTi150's are powered by 2x200w each vs. the 110w & 100w I use now. My current setup uses the Onk powering the front uppers the CS400i center and the Rt800i rears. I have tried using the Onk feeding the bottom woofers and the HK2000 feeding the mid / tweet that sounded to different to the CS400i center. So that is the fear I have if the front mid and tweet amp is different then at least the front mid / tweet's need the same amp, level or not I think the other amp specs have a play in it like you said.
    BTW I use this setup as a 2 channel and HT by the audio mode direct / pure audio modes vs PLII movie mode in HT. As I don't use the nice sub for music.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
