Buttkicker
bkfk
I'm thinking about buying a 'Buttkicker System from The Guitammer Company' for some new Home Theater chairs I just purchased.Does anyone have any views about this system or some other one that I should consider?Thanks in advance for your help.
Post edited by bkfk on
I get the purpose of those things...............but I don't get the logic of people buying them.
What do people think is going to be the longterm outcome of their furniture with something like that on there?comment comment comment comment. bitchy. -
Forget the furniture, pity the poor amp...
2-ohm load with minimum of 400 W required...
http://www.thebuttkicker.com/downloads/ButtKicker%20Concert%20Users%20Guide.pdf
MSRP $399.95 plus an amp? And about as cute as a Pet Rock... Ummmmm.... no....More later,
Tour...
Vox Copuli
Spend the money on a better sub(s). A good sub will provide ample tactile feedback.Go BIG or go home!
Forget the buttkicker. Go with a ClarkSynthesis. It is a much higher fidelity model. I've used 4 of them to shake my living room and compared them with buttkickers at a friends house. The Clarks are much nicer.
Also, if you get the larger Clark model, many reccomend mounting your furniture on a platform, a plywood sheet under couches, or mounting it under-floor. I hear it does very well. Of course, I agree with the better sub theory if there's no WAF or neighbor problems...___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself.
