Are These Fusion Cables...
marly421
marly421 Posts: 73
I've heard good things about Radio Stacks 'Fusion' cable. Of course they are but a memory now but the parts express catalog and there web site makes me believe these 'buy out' cables are indeed Fusions.
Any one who has seen and/or used these; can you verify these are probably fusions?
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=189-076
Post edited by marly421 on
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited October 2004
    Being x-shack, they look very close to the fusions. The only thing I might say is I seem to remember some sort of writing on the connectors of the fusion series. It wasn't overly large, and may just be hidden here, or might just not have em.
    I would say almost definite given the signature 'shack red and white ring, and the knurled grip as well as the shape of the outside of the RCAs.
    'tis a shame they disco'd those... I guess they cant make money selling you a cell-phone with a fusion cable hehehe.....
    The first shack I worked at had a 'bone yard' of sorts in the back with all the optimus components... raw drivers, real parts like crossovers, chokes... all disco. Fusion was their last attempt at quality. Man that company is on the downside of a cliff.
    edit:
    In FACT... this makes me 99.9999% sure right here:
    **Nitrogen injected foam insulation for reduced capacitance
    --This is a patented feature of Radio-Shack cables and is for flexibility as well.
    **Sold by the Nation's largest electronic specialty chain for $49.99!
    --That should make that last little percentage....
    At 10.33 each :eek: ....... Too bad the 'card is fulled up :(
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
    F1nut Posts: 52,172
    edited October 2004
    I bought a pair for the shop rig......not that good IMO. Sibilant highs and sloppy bass.
    VR3 Posts: 29,635
    edited October 2004
    Fusion cables had a 'box' on the ends
    Or is that what this is?
    Inline ferrite toroidal filters on the audio path for greater noise rejection
    F1nut Posts: 52,172
    edited October 2004
    Not a box, more of a collar and yes Sid, those are the same cables.
