DVD-A / SACD disc changer?
gwh
Are there any 5 or 6 disc dvd/ dvd audio/ sacd players on the market at a reasonable price?
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Onkyo DV-CP802. Retails <$500. Anything cheaper than that and you have to ask how well it's really reproducing the formats... (aka Panasonics $100 changers that play DVDa).Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Are you referring to the Panasonic F87 for $129.00? This machine is getting all-around positive reviews not only for its DVD-A playback performance, but also for its CD playback (HDCD capable).
You can also look into the Sony SACD-CE595 SACD/CD changer....like the Panasonic changer, excellent performer. -
I wonder if these reviews are tainted by the affordability factor... or has Sony stood back up to their OLD reputation again for high quality? Ah well, I've taken to beleive Sony will never again make a good mobile audio product, maybe the home market is more, lets say, sophisticated...
I take that back, I work at wal-mart, and people really do buy that crap... (ie, surround 5.1 systems with only a single R-L in... from Durabrand, no less.. --really, there IS no less-- oh, and NOW they make toasters too... maybe Sony should make a toaster...)
___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
with a name like Dura, shoot I'd buy it cause if the name implies it is durable it must be !!
There is a Toshiba 5 disc DVD Audio/SACD changer, sells for about $180 at BB. Don't have any experience with it personally, although I do like my Toshiba DVD-4800 DVD Audio single disc player just fine. I think it is the Toshiba DVD-6915, but can't remember offhand and Best Buy.com doesn't list it. But I have seen it in stores.system 1:
Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
system 2:
XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
2 channel
NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT -
I'll check some of those out.
Thanks 4 your time.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
