Looking for receiver under $500....ideas?
NuckingFuts
NuckingFuts Posts: 77
edited October 2004 in Electronics
If you've seen my other thread in this forum you know Im having issues with my existing receiver. Not sure if I want to spend money to fix it or focus the funds on another receiver. Im sure after getting some suggestions from you guys I'll just go with another one.
Anyway, I would love some suggestions on new or used receivers for under $500 (way under if possible since Im on a budget right now.....hopefully in the $300+ range).
Im going to be running some LS90's that I just picked up as well as some satellite surround speakers for the home theatre. I want to run my old monitor 7's but just dont have the room right now.....I may cut holes in the couch to make room for the more important polks;)
Anyway, if you guys come across any good deals Id sure appreciate the help.
Thanks!
Post edited by NuckingFuts on
