Suggestions for RM6600 replacement
Billm57
I have the RM6600 for auditioning for a month from Crutchfield-Althoguh ti sounds excellent on movies I think for just plain old cd and radio listening it pretty much sucks-even with a sub-Im wondering if I should just keep my Cerwin Vega RE-30 for the the front mains-return the sats and buy a good center and rear surrounds(I would keep the subwoofer) ..any suggestions? I paid 650 for the RM6600 and would like to stay within that price range..maybe a little more...
Post edited by Billm57 on
im thinking of going with the 800i-can anyone give me a good opinion on thses for music as well as movies with a PSW350? As usual..the Jerkit City by me did not have them hooked up-they are by far the worst for a listening room..thats why i ended up with the RM6600 on a trail basis from Crutchfield_i have no place to audtion thses except ordering them and hooking them up..also I have some florr standers now but they are 4 ohm spekaers so i dont know if I can hook these directly to my sub..any help or opinions are appreciated
Billm57-
Check out some of the past threads on the 800's.
I think you'll find nearly universal praise for the 800's.
Great for music. Combined with a sub, great for movies.
-luc -
I've got the RT800i's and I'm very satisfied with them. I listen to music more than movies, and I've got a big 'ol PSW1200 that I run with them. You will want to use a sub with them to bolster their output at the low end, but I think they're great speakers, overall.
Jason -
another vote for the rt800i's. these can be had for the price you are looking in, and they are both great for HT and stereo! enjoy...
well I have a PSW350 sub ..will that mate well with the 800's?
the psw 350 will work with the rt800i's. a 450 or 650 would give you more bass, but the 350 would provide for ample bass in a small room, and it will blend well with the 800's...
