Hooking up a sub to a preamp
Early B.
Early B. Posts: 7,900
Is it possible to hook up a subwoofer to a preamp that only has one set of outputs (for the amp, I presume)?
"God grooves with tubes."
Post edited by Early B. on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2004
    The X-30 sub control from Paradigm would work for you. Using L / R input from the pre outputs / take the main outputs L/R from one of the following 50hz / 80hz / 120hz, the sub has it's own output on the sub control.
    I could post a picture if you need to show you.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2004
    Yeah, what he said.
    OR
    Get some good Y RCA cables.
    Disney Steve!!!
    Cheers,
    Rooster
