What's "transparency?"
Early B.
Early B. Posts: 7,900
edited October 2004 in Speakers
What does it mean when someone says a speaker has excellent "transparency?"
"God grooves with tubes."
Post edited by Early B. on
  • sowen010599
    sowen010599 Posts: 343
    edited October 2004
    It means, when you are playing material, you can look directly at the speakers and you can't tell the sound is coming from them.
    Go BIG or go home!
  • hamzahsh
    hamzahsh Posts: 439
    edited October 2004
    Exactly! agree with sowen010599,
    When I play music on my RT800i's, it sounds like its coming through my center channel. My speakers are angled towards the listener in the middle, so they create a triangle. The angle is more like 60 degress in my room. Also this eliminates some reflections in the room when sound travels from one spot to another, things like wall and furniture can effect the sound alot but they sound perfect and the imaging and soundstage is solid. This is what I called a "SWEET SPOT" and this is where you start to feel the sound.
    IMHO it is an excellent idea to keep changing the position of the speakers and experiment on different angles to make them sound best in your listening environment.
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • Early B.
    edited October 2004
    OK, so as a point of reference, would you guys consider the Lsi7's to have excellent transparency?
    VR3 Posts: 29,392
    edited October 2004
    Ok...
    Dont get me wrong, I agree with what has been said...to an extent
    I want my sound...taking over the room, not...in the center.
    I want a strong center image, but I also want my guitarist on the OTHER side of the mains...
    While doing this, it draws no attention to the speakers
    However, this is only possible through good recordings, period...
    To each their own though
    Basically, I dont want the entire band crammed in a 10 foot space (which is about impossible to do in my small room :()
  • sowen010599
    edited October 2004
    Transparency and imaging are two different things, but closely related.
    Some sounds are supposed to come from the stereo center, some aren't. With really good imaging, from only two speakers, sounds can be heard behind you (very weird). One of the best illustrations of this is Lightning Crashes by Live off their Throwing Copper album. During the guitar intro, with a properly set up system, and great imaging, the guitar swirls around the room. It swirls all around you, infront, beside, behind. It's very strange, just like 5.1 only much more believable, and still with only 2 speakers.
    You can have good transparency with poor imaging. Like hamzahsh said with the sounds coming from the center, that's good, sometimes. Some sounds are supposed to come from there. If you can look at the speaker, left or right, but you can't tell they're on, THAT'S good transparency.
    Then, you have imaging. You can't really have good imaging without good transparency. Good imaging happens when you hear different instruments coming from different places, even to the outside of the stereo pair. Basically, you can close your eyes and hear the whole band spread out in-front of you, taking up the whole room. You can point to the place where each instrument is playing.
    Lsi 7's, well, they're good if your in the "sweet spot" but, move in any direction and their imaging and transparency collapses. If you are "in the triangle" they're pretty good.
    Go BIG or go home!
    VR3 Posts: 29,392
    edited October 2004
    Yes, I always plant the guitars on the sides, voices/drums in the center
    In my room, I have very good imaging - from side to side, front to back, and center...
    Transparency is kinda hard to achieve when sitting 4-5 feet from tweeters...but it is as close as I can get it within my lil abode...
    What I meant was, if you have EVERYTHING in the center -- you have problems. Plain and simple, lol
    Soundstaging, transparency are the first things I look for in a speaker. If it can do one or the other, I dont even consider it
  • dcarlson
    dcarlson Posts: 1,740
    edited October 2004
    Umm... I think you guys are talking about imaging and soundstaging.
    Transparency is when a component recreates exactly what it is fed and is "transparent" in the chain of components. Regardless of imaging and soundstaging.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • Early B.
    edited October 2004
    OK, so can someone clarify all this for me? If the definition given above is correct, how is it possible to determine whether or not a component is recreating exactly what is fed to it? Seems to me there's only one guy who could know what it's supposed to sound like, and that's the fella who mastered the original CD/DVD. Taking another approach, if this definition is correct, then it's not possible for any component to be transparent because they all add their own flavor. Hell, even the freakin' room has got something to contribute.
    Just trying to gain a better understanding. I hear these words being thrown around all the time when describing speakers and other components, and most of these words may be just a bunch of hogwash.
  • dcarlson
    edited October 2004
    That's the fun in READING about audio, no? ;)
    Personally, I think it best to listen and if you like what you hear, buy it (if you can). It's all subjective upon the writer. It's hard to buy based on writen opinions but writen opinions can steer you towards listening to a good component.
  • Early B.
    edited October 2004
    Agreed. Virtually every professional review paints such a rosy picture that it's hard to distinguish the good stuff from the great stuff. That's why I prefer to read consumer reviews. Unfortuantely, too many consumers try to sound like professionals and use a host of meaningless terms.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    ED Zachey... Transparency = lack of coloration...
    Coloration = the degree to which a given component, or sequence of components add their own, audible signiture to the signal being reproduced...
    Example: The old SL2000 tweeters added a hump around 15 kHz, i.e., they colored the sound.
    Coloration is not necessarily a bad thing, if you are in control of it, e.g., judicious use of an EQ. Al you are doing is tayloring the music to fit your ear, just as the sound engineer did to fit his...
    EDIT: How can you know when your rig is colorless... can't really... What you can tell is when a single change you make moves the sound of your system away from where it was in one direction or another... Mostly if it's more pleasing, a reviewer will say it's less colored. If it is less pleasing, nasty ol' coloration...
    Forgot to mention above that your listening room is also part of the equation..
    More later,
    Tour...
    Vox Copuli
  • mantis
    mantis Posts: 17,318
    edited October 2004
    Ask a hundred people and get a hundred different answers....
    In the audio world, people make up there own words to describe what they hear....
    Dark sounding , Cool , clear , Muddy , boomy , airy , bright , dead , colored , etc.
    These words mean different things to diferent people. We somewhat have an idea what the hell people are saying....but not always.
    You'll hear / read new ones all the time. Not to mention you'll start making up your own.
    Listen and you'll see.
    When I use the word " Transparency " what I mean is the speakers go away in the room. The sound is coming from the room not pin point to the speakers. Like the center channel coment , the sound is in the room sounding like it's coming fromm somewhere else.
    Transparent also can mean that the instruments are floating in thin air.
    Dan
    Dan
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2004
    Originally posted by mantis
    When I use the word " Transparency " what I mean is te speakers fo away in the room.
    Thanks for clearing that up for me. Makes perfect sense now.
    Lucky numbers: 15 22 36 41 47 59
    Cheers,
    Russ
  • mantis
    edited October 2004
    Edit the last post it reads correctly now
    Dan
  • Tour2ma
    edited October 2004
    FWIW... taken from:
    http://www.audiovideo101.com/dictionary/dictionary_cat.asp?catid=18
    Transparency A subjective term used in audio to indicate how easily and how much of the sound of the live event comes through a recording when played through an audio system.
    More later,
    Tour...
    Vox Copuli
  • Early B.
    edited October 2004
    Wow, that definition of "trasparency" means nothing.
    OK, so what do we make of all these so-called expert audio reviewers who throw these buzz words around if they have no real meaning? If the buzz words are meaningless and the specs are meaningless, then the only way to judge the quality of speakers and other audio gear is by hooking them up to your existing gear in your room and listen with your ears. Damn. No wonder some of you guys trade out gear so often. There's an inifinite number of combinations to try out and it's virtually impossible to compare one setup to another.
    Geez, I need a new hobby...
  • Tour2ma
    edited October 2004
    Easy, EB... wasn't my definition either... Just one I stumbled across...
    More later,
    Tour...
    Vox Copuli
