Restored Eico HF-81
00p225
00p225 Posts: 100
edited October 2004 in 2 Channel Audio
I recently bought a 1959 vintage 14wpc Eico HF-81 integrated tube amp on ebay. The seller had upgraded the filter caps as well as most of the other caps except the ceramics which tested ok. Tube compliment is mainly Eico by Mullard, except the EL84's which are Eico, made in spain? They do sound good though. I bypassed the funky focus (balance) control which introduce gain and increased the volume when moving to the right or left channel. For the chassis, I painted the main panels argent silver, polished clearcoated the brass faceplate, and painted the cage gold to compliment the faceplate. These are really sweet sounding amps, and the phono amp is not bad if used with a mm cartridge.
Main System
Pre - Homebrew 12au7 tube preamp
Amp - Eico HF-87 with EHEL34's
Source - Modded Toshiba 3950
Interconnects - DIY Belden
Speakers - Polk SDA-1C
Basement System
Pre - McIntosh C-28
Amp - McIntosh MC2100
Source - Modded Toshiba 3960
Tape - Pioneer RT-707
Turntable - Thorens TD150MKII with Denon DL-160
Speakers - Pioneer HPM-100
Post edited by 00p225 on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited October 2004
    Sweet! Real nice!
  • madmax
    madmax Posts: 12,434
    edited October 2004
    Very nice!
    Vinyl, the final frontier...
    F1nut Posts: 51,747
    edited October 2004
    I like!
  • 00p225
    00p225 Posts: 100
    edited October 2004
    I tried this little integrated with my Polk SDA-1C's and was pretty suprised at the result. It drove them well above normal listening levels, and the sound was just plain lush. Nice wide soundstage, and rich bass. Really a good match with the passive radiator design of the sda's.
    Main System
    Basement System
    Pre - McIntosh C-28
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Sweet... More "after" pics, if you please...
    How'd you polish the face w/o removing all the lettering?
    More later,
    Tour...
    Vox Copuli
  • 00p225
    00p225 Posts: 100
    edited October 2004
    The letters are imprinted or pressed into the brass, so I just polished the faceplate with Flitz polish, repainted the lettering, then used paint reducer to wipe away any stray black paint on the surface which just left the paint in the lettering indentations. This is the only other pic I currently have, the good thing is it still sounds better than it looks even after the new finish;-)
    Main System
    Basement System
    Pre - McIntosh C-28
  • gidrah
    gidrah Posts: 3,049
    edited October 2004
    That looks great! Eico is definately an under appreciated brand. Not too many people own them, but the people that do are very happy.
    Make it Funky! :)
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2004
    Great work, looks cool!
