Sony RM-AV# remotes?
Bonham
Just curious if anyone has had any experience with these remotes?
The Sony RM-AV2500 and RM-AV3100
I'm looking to pick up a single remote to do as much as possible on my entire living room setup (receiver, tv, cable, dvd, cd, etc, etc).
Link on Overstock: http://www.overstock.com/cgi-bin/d2.cgi?PAGE=PROFRAME&PROD_ID=737878
Just... Bonham
Hitachi 52" Rear Proj' HDTV: 51XWX20B
Comcast Motorola HD/DVR Cable Box; DCT6214/2005
Sony Prog' Scan DVD; NS752P
Harman Kardon AVR 7300 Receiver
Harmony 659 Universal Remote
Polk Monitor 70 Front Mains
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds
Post edited by Bonham on
Yeah, I had one, but didn't like it, so I returned it. Not very fond of the screen thing. I like buttons. Check out the Harmony remotes. For less than the price of the Sony's, you can get one that you program via a computer. It's on my wish list.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Ah, excellent. Thanks for the tip. Gives me another remote that actually looks even more what I'm looking for (i.e. the ladies in the house can never figure out my system... so the "watch a movie" button feature will make them happy). And the ability to program it via the computer sounds a heck of lot easier.Just... Bonham
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds -
An excellent site to check out is www.remotecentral.com. It has more info than you'll ever need for just about every remote out there.Brian Knauss
ex-Electrical Engineer for Polk -
Heh, the web site says to do a 'test drive' before you buy to see if you like them. I sure hope the remotes work better then their web site... because it almost appears as if the 'test drive' is merely a way to get info on you and I never did get it to work. :mad:Just... Bonham
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds
