A couple questions about RTi100 + surrounds etc..
Dannieboiz
Dannieboiz Posts: 242
edited October 2004 in Speakers
I've had my RTi100 for awhile now but haven't had the time to finish up my setup. I ran into a guy that was selling some
FX500i
CS245i
and threw in Energy Subwoofer E XL-S8
all for 250. I'm pretty sure I got a steal, hooked them all up and it sounds great. But, I know these are not matching surrounds for the RTi100. Is it worth while to consider going from the cs245i to CSi30 or even Csi40?
Swap the FX500i for some FXi30?
They're all powered by my HK AVR500
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited October 2004
    You got a terrible deal, but to help you out I'll give you the $250 you paid for it all so you're not out any money.
    Really though, the only way to tell is to listen for yourself. If you like them together, keep them. If not, then try something else.
    Tschüss
    Zach
  • Dannieboiz
    edited October 2004
    Thanks it's 7am and you just ruined my day. LOLZ:rolleyes:
    Well anything would sound good now since it's the first time all of my components are somewhat matching. I was using some crappy KLH for the center which I couldn't even hear vocal at all and the RT15 in the rear was barely hizzing @ high volumes. I can actually tell the center from the fronts and the rear actually sounded like they're coming from the rear now.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • okiepolkie
    edited October 2004
    I hope you know I was joking. It was a good deal(I just want your speakers).
    If they are in good shape, I would have paid that much for everything just like you did.
    Tschüss
    Zach
  • Dannieboiz
    edited October 2004
    Yah I know you're joking, can't you see the sarcasm :rolleyes: <~
    They are in excelent condition, not even a single scratch on them.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • okiepolkie
    edited October 2004
    Poor monitor resolution. I couldn't tell what the little smiley icon what doing.
    Tschüss
    Zach
  • Dannieboiz
    edited October 2004
    That bad eh? not sure if I can post other sites here but if you go to fatwallet dot com they got some crazy deals over there once in a while.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Airplay355
    Airplay355 Posts: 4,298
    edited October 2004
    i think you will be fine, especially in the surround department. the only thing i think you migh tnot like is the size of the cs245i. it might seem over powered by the mains.
  • Dannieboiz
    edited October 2004
    for some strange reason I feel as if the center are quite loud and big. It's sitting on top of a 60" wide screen tv and it's probably 1/3 of the tv's lenght. So far I've been nothing but impressed, I'll stick with it for a few months before I get bored. The new RT12 sound pretty attractive too just waiting for the price to drop a little more on those puppies.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • okiepolkie
    edited October 2004
    Have you checked at your local Circuit City for the RTi12's. I know one here in Memphis still has a pair or so for under $1000 on clearance. If I were serious about buying them, I could probably get them for closer to $900, but I've already spent my electronics quota for the year.
    Enjoy your new setup.
    Tschüss
    Zach
  • Dannieboiz
    edited October 2004
    Fry's usually have blow out deals with new models arrive. I got my RTi100 for 280 bucks a pair last year. I'm gonna hang out until the RT12 drop below 500 before I take a bite. My buddy works @ Fry's and he told me the mark ups on those speakers are outrangeous.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Airplay355
    edited October 2004
    when i used my cs245i with my rti150s the rti150s definitely over powered the center. but my system wasnt calibrated so that could probably be avoided by calibrating.
