LSi7 vs LSiFx for surround duty
I'm looking to replace my worn Cambridge Soundworks sats that have been my surrounds with something a little better.
I'll probablly end up keeping them for the rear channel in a 7.1 setup, but in the meantime can you gents suggest whether the LSiFx surrounds will sound better than adding another set of LSi7s?
The only issue I have is that I cannot place the surrounds next to the sofa as this is an active walkway. They will be hanging on the wall about 4 feet behind the sofa. So, the rub is that the right surround has no wall adjacent to it. It opens into a hallway (Imagine a dogleg)...
So, I am just wondering if that LSiFx is going to be wasted, throwing the right side of that speaker out into space. While a simple LSi7 pointed forward would be cheaper, would it sound better than that fx in this application?
Also, what's the best place for the rears if the surrounds are on the back wall, too??
Here is a little chart-
7= Lsi7 (current)
S= Surrounds in question (5.1), LSiFx or LSi7??
R= Old speakers perhaps used as rear surrounds (7.1)
Thanks- Rob
7= Lsi7 (current)
Thanks- Rob
Yamaha RX-V1500 // Outlaw Audio M200 (x2) Panasonic TH-52PZ700U
Sony DVP-NS715P // Sony Playstation3 // Roku Soundbridge M1000[/color]
Polk LSi15 (w/Monster Z2 Wire) // Polk LSiC // Polk LSi7 // Velodyne DLS-3500
Workshop Rig: Creek 4330 // Technics SL-P310 // Cambridge Soundworks Ensemble 2
Post edited by RobXant on
You can't hang the surrounds from ceiling?
How would I do that? Susspend them on wires down 3 feet?
Not only would the wife ****, I could see myself getting knocked cold during a refrigerator dash!
RobYamaha RX-V1500 // Outlaw Audio M200 (x2) Panasonic TH-52PZ700U
Workshop Rig: Creek 4330 // Technics SL-P310 // Cambridge Soundworks Ensemble 2 -
Yeah, I agree with hanging the surrounds from the ceiling. Your layout doesn't really lend itself to a setup that comes close to optimizing 7.1. Consider sticking with 5.1. It'll sound just as good, probably better. But if 7.1 is what you're looking for, you can find plenty of ceiling mounted speaker brackets to fit your needs.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Ditto the above. 5.1 LSiFX for the backs.
If you REALLY must go 7.1, I'd use 7's all around to keep from muddying the sound fiels with 4 speakers on your back wall.
Simple note: If there are more speakers behind you than in front, you have issues...There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
So sticking with a 5.1 setup, then would the LSiFx sound as good as it should, or is the LSi7 (mounted in the same place) the way to go?
There are much better ways to do it than that.Originally posted by RobXant
Considering how high from the ear the surrounds should be, and how high they can be, I found that ceiling mount is more ideal in my room plan than wall mount. -
I really can't see mounting an LSiFx to the ceiling, so sticking with the 5.1... Will Fx or 7??
Whether you go Lsi7 or LsiFx is not a straightforward answer. Just depends mainly on your listening preferences. For your room setup, I'd personally stick with 7's in the rear -- they're less expensive (the increased price for the LsiFx's is probably not worth the perceived benefit) and you maintain the best possible timbre match.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
