Speaker Switchbox
dharding
dual banana plugs?
Only half kidding, here. If all your speakers accept dbp's (Hey, a new acronym... ), it's as fast and clean a method as you can do.
You're obviously getting "bleed-through" to the speakers that are off-line. The contacts in the selector may be dirty or faulty, or maybe the switcher is not rated for the wattage you are pushing...
Issue with A-B'ing speakers through a switching box is matching the spl, and that adds rheostats (sp?) to the mix. If volumes aren't match the more sensitive/ efficient speaker will be louder to some degree and will usually sound better (assuming the speakers are close in SQ). The issue with switching boxes and rheostats is they add a lot of "junk" potential to the signal path.
If you want to persist in your mad scheme , go to your local audio store and ask about the selectors they use. And/ or do an internet search. Might come up with a schematic and then a trip to your local electronics store ought to net you a "cheap" route.More later,
Tour...
Vox Copuli
You could do this project: http://sound.westhost.com/absw.htm
I'm sure there's a multi-way selector you could use instead of the switch in the specs.Brian Knauss
ex-Electrical Engineer for Polk -
Just connect the speakers to the receiver.
Pair 1, A
Pair 2, B
Pair 3, Zone 2Go BIG or go home! -
Saw a 6 speaker box by Phoenix on ebay... Starting bid could not be lower, but I think the Seller is way out in left field with his shipping charges...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5724063416&ssPageName=STRK:MEWA:IT
No affil... no endorsement, just happened across it.More later,
Tour...
Vox Copuli
It's most likely due to the close proximity of the connections inside the unit.Make it Funky!
... that, and dirty contacts...More later,
Tour...
Vox Copuli
