wut kind of subs should i get
downeywu
i like hard hitting bass, and i was wandering wut type of subs i should get and wut kind of amp, i wanted to know prices and wut else should i know about getting a system
Post edited by downeywu on
give us a price range, also tell what size of subs you have room for (can you fit 12's or do 10's work better in your car).
just for a reccomendation of what i like best with no parameters... i'd say 2 12" adire Brahma's running off of a US Amps USA-2000... 1kw of clean power to each sub... you'd shake the trunk off of your car lol... but that would run you around 2500 just for subs and amp, then there's wiring... possibly a new alternator, at least a rewound one, better batteries (all due to the large amperage draw from that amplifier) and you're looking at over 3g... so you can see the importance of giving us a price range to play withMacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
getting a 'system' generally implies that you're going to get full-range upgrades... that is, at least coaxial replacements for your stock speakers, and sub(s)... even if you only want subs, spending $200 on some decent coaxes makes a world of difference... also, do you have an aftermarket headunit? they come in very handy if you're going to amp anything, and amp you must if you're running subs. do you have any plans for expansion? as mentioned, what's your total price limit? and do you prefer crazy loud bass or tighter, more musical bass?It's not good, very fundamentally simply not good. - geolemon
we need to make a sticky to prevent these kinds of posts...
why, it's fun when we get another 'wander'er every once in a while?It's not good, very fundamentally simply not good. - geolemon
Yeah me too. These are my facvorite threads where we get to recommend things. It lets us piece together different systems for fun.
Like this ID Max 12" sub paired with this hoss Crossfire VR1000D.
Or for supreme decibels go with this Orion H2 12" and this monster MTX Thunder 1501D.
Thats the kind of setups I like. A single sub looks modest, but an H2 with 1750 watts is anything but humble!polkaudio sound quality competitor since 2005
i prefer the more subtle "whoa" effect... when you can't tell there's anything there until you sit in the car and listen... then you're like, "whoa..."
unless of course the top's down, then everyone and their brother can hear it...
My woah effect is in my sig... really it's that quiet outside... all with no visible mods to the car...
Edit: Though I should be more modest than saying 100%....___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
I too am a big fan of the stealth install. I love the systems that the only component you can see is the head unit. Then when cranked up you hear the wonderful, clean sound coming from nowhere! Hopefull that how mine will sound once I get some gawddamned money coming in!!! :mad:
I need a better sub and I need component speakers!!!polkaudio sound quality competitor since 2005
Originally posted by MacLeod I need a better sub and I need component speakers!!!
and yeah, i kinda am starting to step away from the subtle whoa effect, at least for the car as a whole... this is probably going to be my next car-related purchase (not the car, the body kit around the bottom):It's not good, very fundamentally simply not good. - geolemon
Originally posted by neomagus00
for as much as you know, yes, that's true....
Huh?polkaudio sound quality competitor since 2005
for as much as you know about car crap, you need to have a system to match the mind...It's not good, very fundamentally simply not good. - geolemon
So is that a compliment or a dig?polkaudio sound quality competitor since 2005
compliment... now, me telling you you're old is... well... true?It's not good, very fundamentally simply not good. - geolemon
im from argentina, i buy an Alfa Romeo 145 one week ago, and i want to mount my first Audio System....
i want to spend like 2000 U$S in the whole system...
can someone tellme an good conf for that money?
i dont know if its enought....
well, sorry for my english.... hope you understand what im trying to say.. and... i want to spend 2000 in just drivers / subwoofer and Amps...
thanksTesting
Testing
Testing -
Oh, I love threads like this!
$2000 will get you an outstanding system
You can get something like MB Quart Premiums ($500) for your front stage.
Then something along the lines of a JL Audio 12W6 ($450).
Then run an Xtant 4.4 ($500) for the fronts and an Xtant 6.1 ($500) to the sub.
This would be strictly a SQ setup but it would get plenty loud and sound awesome assuming proper installation!polkaudio sound quality competitor since 2005
hey MacLeod, in other post we talked abt the Polk Audio Setup, you think that with this conf (JL, MB) ill get better sound ?Testing
Testing
Testing -
Polk Audio and MB Quart / JL are in two different leagues. MBQ and JL cost considerably more so naturally youre going to get more.
Dollar for dolllar Polk beats em hands down but if youre willing to spend $500+ on a set of speakers there are better out there. If youre budget is $350 or less you can beat the Polks.polkaudio sound quality competitor since 2005
JL cost considerably more so naturally youre going to get more.Music is like candy, you have to get rid of the rappers to enjoy it -
exalted, what do you think abt the speakers?
will be better to get a few more bucks and buy the MB Quart / JL ?
or i dont will get too much difference? -
im not a fan of MB Quarts new stuff and i definitely do not like JL. there are much better speakers out there than polk. but if under $350 is what you want to spend then polks are for you.
y'all keep tellin' him his budget for speakers is $350; he hasn't said that yet......George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
ok, i dont say anything abt the amount that i want to spend....
but, if i want to spend 350 polk is the best choice.... and if i want to spend 400-700 ? -
$400-700?
MB Quart Premiums
Focal Polyglass
Focal K2 Power
JL Audio XR
Diamond Audio Hex
Alpine Type X
Boston Accoustic Pro
a/d/s
just to name a few
$0-350
Polk Audiopolkaudio sound quality competitor since 2005
$700 can get you some good Focals
thanks guys
