capacitor?
beavis240
so i have MMC6500's MMC690's and 2 MM12's in my honda accord. im gonna run the C400.4 for the speakers, and C300.2 for the subs. I know this is takin a lot from my battery so i wanted to know if i would need a capacitor? or two? i dont really know a lot of that kinda stuff. any suggestions on what to do or what brand capacitor is good?
Post edited by beavis240 on
are your lights dimming?
i don't think the stuff is installed yet... in any case, a cap can never hurt; amongst the name-brand people, look for low ESR (equivalent series resistance; it'll be mostly the same amongst caps) and get a round cap, not a square one. other than that, get whatever you think looks good. if you can, get an optima yellow-top battery, even if you have to forgo the cap to get it, this will help you more. sometimes a cap won't help light dimming, in which case you can simply put small capacitors in the headlight line - no more dimmingIt's not good, very fundamentally simply not good. - geolemon
ACK...NO cap is needed- Period
Dont be fooled into wasting your time or money on a cap
Next....:mad: -
figures....he doesnt post in a few months and when he does its about a cap...lol
I agree with TUI. Ive seen to many kilowatt+ systems with stock alternators and an Optima battery and they all worked fine.polkaudio sound quality competitor since 2005
hehe, I'm about to put a kilowatt into my little 80hp car.. we'll have to look at gas mileage changes before it's over... maybe I'll find a good GM truck altenator to squeze in there.... Other than that my yellowtop works just fine for most cases, and the 700w I used to run just barely dimmed the lights.
-Jerry___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
hmmm.... only reason i rec a cap is because of the strain it seems to put on a battery... now, i have absolutely no factual evidence, but it seems to me that pulling power then pushing it through the battery at a hundred times per second isn't so good for it, whereas if you use a cap, which is designed for exactly this, the battery only sees a load of on or off (i know this is simplified, but it gets the point across...) can this changing draw harm a battery? is there any harm in adding a cap?It's not good, very fundamentally simply not good. - geolemon
they have something called a "batcap" now...do a search for it in google...supposed to be really good
unfortuanatly....caps do not "relieve" the strain on the battery. If anything...the battery has something else to charge!
Cap= a/c filter -
Cap= a/c filterIt's not good, very fundamentally simply not good. - geolemon
Problem is...cap cant charge and re-charge quicke enough to keep up with most music.. so its kind of pointless.
Caps can be useful on mids in high end systems to help extend dynmaics...about it....other wise there are better options then caps -
i'm not sure what you mean by 'charge and recharge quickly enough to keep up with most music', could you elaborate a bit? at the very least, if a cap can't keep up with a bassline, how's it gonna deal with midrange, a factor of 100 times faster (higher frequency)?It's not good, very fundamentally simply not good. - geolemon
exactly cody.... lower frequencies require more movement and thereby more power to reproduce, hence the fact that most lower end subs run around 300-400 watts whereas most component sets run 100-200 watts, higher end subs run from 600-1500 watts per sub... 1500 watts for one speaker vs 150 for 2...MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
yes, clearly bass requires more power, but the cap isn't intended to take the load off of the battery entirely, it is intended to buffer the ac draw from the battery. the current draw from the battey without a cap would be the absolute value of sin, or the position function of a perfect bouncing ball, or... um... a bouncing bunny (roughly, for all three, the small caps in the amp should mellow this out a bit)? so all the cap does is draw a constant current from the batter, presumably at .707 times the peak of the current draw from the amp (just the average), while allowing the amp to have it's way with the cap. if you have sufficient capacitance, with any pause between bass notes (even with an overdraw from the cap), you'll see a full recharge. is that written clearly?It's not good, very fundamentally simply not good. - geolemon
not only that, but you have to keep in mind the additional benefit of the cap over the battery. the battery shows a resistance to the line of current, mainly because it's cells actually ahve to react internally to produce the power. this is why it has a detrimental effect on AC draw. A cap copmes in handy, because the super-fast discharge rate makes it show a superbley low circuit impedance. THIS INCREASES YOUR PERFORMANCE!!! this is why it helps.
Now, there are two types of capacitors, one is electrolytic, and the other is di-electric only. the electrolytic is higher capacity but has a slower rate of discharge. this is why caps arent the solution to every power draw buffering problem, but they help. A strictly di-electric capacitor hold's very little energy, but is capable of speeds of discharge equivalent to how fast the electricity can travel down the wire!
The (electrolytic) capacitor's electrolyte layer is usually under one hundredth of an inch thich... let's compare this to the 1/4" between plates in a car battery...... now do we see why a car battery holds more, but has a higher impedance?
You CANNOT have a capacitor FOR your battery, as it would be the size of your entire car. However, you CANNOT expect a battery to behave as fast as a capacitor. The combination of the two allow us a much better power supply. In fact if you had enough money and you cared enough, a bank of the battery, a good electrolytic capacitor, and a large di-elecrtic capacitor would even out your supply to it's maximum. However the internal workings of your audio equipment will take care of any need for the latter type of capacitor.
Please, if you want a capacitor, go for it. It is neither a waste in time or money.
-Cody
Lots of marketing. Marketing is the tool of the devil... also known as B*se.Brian Knauss
ex-Electrical Engineer for Polk -
ive heard a few ppl that have a pretty big knowledge of car audio endorse it...
endorse as in say its good...theyre not getting anything out of it
but its pretty new, so i guess time will tell
Having a big knowledge of car audio and having knowledge of electricity can be two completely different things at times.
That's my 2 cents.Brian Knauss
this is true, but what do you think about the batcap?
-Codyhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
it seems like a good idea, but i would prefer a standard optima/cap setup for two reasons - one, the standard is proven, which is why it's standard, and the batcap is new and unproven; two, the bright battery and shiny silver cap look way cooler than the dull white or black of the batcap
. it seems to be doing well in spl comps, or so the site says, but time shall tell.
p.s. bknauss - in what way is a fundamental knowledge of electricity and electronics different in home and car applications?It's not good, very fundamentally simply not good. - geolemon
well, there's clearly differences, such as that 120 volts being ac and the 12 being dc, but fundamentally, once you realize things like that, is there a difference?It's not good, very fundamentally simply not good. - geolemon
no
electricity doesnt change just because the numbers do...
the biggest difference is voltage since a lot of the internals of amplifiers is different
no, i know that the electricity doesn't change, that was the response i was trying to get from bknauss
. the point i was making with the ac vs. dc was that you can't use them in exactly the same way... you try to put 12 volts ac into a car amp and you are either going to have a dead amp or some very trippy music.
Home VS Car... Not a bit of difference...
The home equipment has less disadvantages to BUILD, but using it is the same. Most of the Extras we add to car audio are not needed in home because of the power source, and home can use all the space they want. The electricity remains the same, however, less the fact that at lower voltages more energy is wasted as heat than higher voltages.
As for the BattCap??
The batcapp is only a new model of an old thing. simply a different electrolyte that has more joule-holding power. You're right about the 'proven methods' though (NEO), we may see this new electrolyte eating through the casing in a few years, who knows. I will however say that you can get a 1 Farad cap the size of a cm-thick penny. It only handles about 1.5 volts and will run you a high dollar (you could build one for your car out of 10 of them in series for 15v, but do you have over $700 to blow?).
There are lots of better caps out there, we just don't feel like affording the room for the cheap ones, or the money for the small ones. So go with what the market has found the most affordable and reliable.
wait a dog gone minute. The electrical systems of a house and a car are COMPLETELY different.
A house is fairly simple... 120V +/- 10% at 60Hz. Unless you're in CA or about to have a blackout, you'll hardly ever see it really swing to that +/-10%, even with heavy current use. If you use too much current, the breakers switch off and you're without electricity until you switch it back.
The car is different. The battery is generally 12V, your alternator charges at 14.4V, and as we all know, the alternator can't always stick up at 14.4V. This is due to the battery needing to output more current that the alt can't provide, so it sags, and generally you never get up to 14.4V, and if you do, its for short periods. Then you start throwing in that the alternator provides different current at different RPMs, it makes it a fairly unpredictable system if you're playing music. I drove around one day with a meter on an amp and looked at the voltage (this was with a C300.2 and a 1kW amp). When I was playing bass heavy music loud, the voltage was hanging around 12.5 to a little over 13 for most of the time. There were a couple times I dipped below 11V. When I had the music low, it would stay more stable around the mid 13s. If we say 14.4V is what the voltage is supposed to stay at, and say 12V is the greatest amount of change, we're talking about a 20% swing in voltage... much more than the 10% you'll barely ever see in a house.Brian Knauss
BK, I was explaining the use of electricity is the same in both, in response to your post ofBKnauss: Having a big knowledge of car audio and having knowledge of electricity can be two completely different things at times.
But, thanks to Anal Correction Man we now know the difference in power supplies. Also know that your vehichle's battery can drop to below 6 volts when cranking... fun, fun!
edit:/\ How's that for a percentage of swing, eh,? (58.3%)
the question was: in what way is a fundamental knowledge of electricity and electronics different in home and car applications?
to me thats a no...the fundamentals of electricity is the same whether the voltage varies or not
thats what me adn jerry were talking about
