testing
gatemplin
crossover
[IMG]C:\Documents and Settings\Templins\My Documents\My Pictures\Crossover.JPG[/IMG]
Graham
Post edited by gatemplin on
It's a 4th order Linkwitz Riley parallel crossover with 3dB of baffle step compensation and 6dB of attenuation on the tweeter.....I hope:DGraham
without getting out the calulator or pspice the tweet will receive half the real current since the tweet is ~ 6 Ohms. I think 1/2 power is about 6 dB spl... or close enough for government work.
HBomb***WAREMTAE*** -
I think the first 3 ohm resistor would drop half the voltage, then the 6 ohm in parallel would eat half the current. So the tweeter actually sees one quarter of the power, 6dB less output. A 3dB increase takes double the watts. I got the values from a Lpad calculator.
What I am unsure of is the Low pass crossover values and the bafflestep compensation. I am still a newbie at this.Graham -
Ed ZacharyOriginally posted by gatemplin
again agreed but I always confuse sound pressure and electrical power.Originally posted by gatemplin
assume low freq and and now the circuit is a series lr. Xl=2(3.14)*F*L so as low freq increases so does resistance. I would assume the sub impedance is 1 then trend it.
been a long time
HBomb***WAREMTAE***
