FXi5's Placement
captain
captain Posts: 6
edited September 2004 in Speakers
Hi,
I have been tossing up between RTi6's and FXi5's.
Thanks to those who posted a reply to my previous thread. Greatly appreciated.
FXi5's seem to be the shot.
My quesion is, regarding placement. Do the FXi's need to be placed against a wall? As per the picture on the polk site.
In the pic they are either placed against the side or rear walls such that sound can bounce off the walls.
I need them to be placed in the open with the side wall being a window and the rear wall being several feet away? Would they still work effectively?
Any infomation on FXi placement greatly appreciated.
Cheers Lee.:D
RTi12 front
505 Sub
CSi5 centre
RTi4 rears
Surrounds ??
Denon 3805
Captain Lee
James Cook University
Townsville, QLD 4811
Australia
  • Airplay355
    Airplay355 Posts: 4,298
    try it out that way, put them on top of something and see how it sounds. i don;t think that putting them there would be a bad idea. i bet you could pull it off.
  • Early B.
    Early B. Posts: 7,900
    Sure. Buy some stands or make your own. A couple of guys here have done that.
    "God grooves with tubes."
  • PolkThug
    PolkThug Posts: 7,532
    They'll be fine. You don't really want the sound bouncing off the walls (at least I don't).
    Regards,
    PolkThug
