Sub Sizing
Systems
would a 12" inch sub have any advantage over a 10" sub, even when both of them were from the same manufacturer, same model, and have identical resistance/coil design, and identical factory rated RMS and peak power?
Testing
Testing
Testing
Testing
Testing
itll be louder due to more displacementTesting
Testing
Testing -
yep, the 12 will be a bit louder and a bit deeper, but sometimes the bigger sub (with the same specs) will sound a bit looser than the 10. and it takes up more room.It's not good, very fundamentally simply not good. - geolemon
My general rule is to go with the biggest sub that is practical. The biggest considerations are size. A 12 will usually need a box in the neighborhood of 1 cubic foot where a 10 can be perfectly happy in a .5polkaudio sound quality competitor since 2005
the 12" has 113.4"sq. and the 10" has 78.5"sq. of surface area. this translates into a HUGE displacement difference, also the design of a 12" cone inevitably makes it weaker, so it needs a bit less pressure behind it to be safe, which is why the box must be larger. However you get a good increase in ability to reproduce lower freq's and get a better sensitivity output.___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself.
