AES/EBU interface on Parasound DAC?
Emlyn
Emlyn Posts: 4,535
edited March 2006 in 2 Channel Audio
I recently acquired a used Parasound D/AC-2000 Ultra DAC and it has the ability to connect with a compatible digital source with an AES/EBU interconnect. I'm just using it with an unbalanced coaxial cable for now, running the digital signal from a CEC CD player although the CD player also has an AES/EBU output as well. The improvement in sound quality is quite noticeable with the external DAC even without using an AES/EBU cable.
Does anyone have experience with using components with an AES/EBU interface? There seem to be some cheap generic AES/EBU cables available for a low price and some with a very high price too. Is it worth buying a new cable (balanced 110 ohm) to use in place of the coaxial?
Post edited by Emlyn on
  • madmax
    madmax Posts: 12,434
    edited September 2004
    My Theta/AudioNote setup uses this cable. The fellow I bought it from said the cable should be of good quality. The one on mine was around $300. I've often wondered what the difference between this and the standard connection would be but unfortunatly this is the only connection on mine. No help I guess...
    BTW, look into the polk replacement tweets for your SL-3000's or SL-2000's. They are quite nice. :)
    madmax
    Vinyl, the final frontier...
  • Emlyn
    Emlyn Posts: 4,535
    edited October 2004
    madmax
    You're always a help, Chuck. I probably wouldn't be able to tell the difference between cables if I was still using my old speakers. It's difficult to find information on AES/EBU cables, although I have seen some people say that either coaxial or AES/EBU cables work better with external DACS than toslink cables. I think I'll stick with coaxial until I get more information, since it seems to cost more than what I paid for the DAC to get a short high end AES/EBU cable. I'd probably spend as much on a cable as it would cost to upgrade my SL-3000 tweeters on the 2.3TLs, and replacing the tweeters is a higher priority right now. I have replaced the SL2000 tweeters in SDA 2s as recommended by Dorokusai, and they are very nice.
  • Normanality
    Normanality Posts: 297
    edited March 2006
    Greetings Emlyn. I've got the same Parasound 2000 DAC and found that the sound was a full step better using the AES/EBU over the coax digital. I've been using a Nordost Silver Shadow AES/EBU and also have a Kimber coax digital.
    Other than the impedance difference 110 vs 75 I'm not sure why there is such a difference in sound.
    I'm going to be selling my DAC also (I have 2 of them) since my Parasound 2000 transport finally gave up the ghost and I've moved onto a Jolida modded tube cd player.
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    I've used AES connections on some recording stuff. Didn't notice any diff vs coax, but the gear wasn't very high-end. Basically just an 8 track HD recording setup.
    Backburner:Krell KAV-300i
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2006
    I run my CEC CD-3300 via AES/EBU into my Benchmark DAC, and I prefer it to my connection via DH Labs coax, which I tried for a few months. My AES/EBU cable is from Signal Cable, 2ft length.
    The AES/EBU connection seems to have a little bit smoother treble than coax, but I'm not thoroughly convinced yet, thats it's not a placebo effect.
