A good full range driver?
VR3
VR3 Posts: 29,762
edited September 2004 in Speakers
Well...
I am just looking at some options here....
What are some fairly decent full range drivers...out there (no more than 60 bucks each) - that don't require a larger cabinet, would like a 5.25" - 6.5" FR driver.....
Any options that come to mind?
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Fostex FE166E - $61 each
    Fostex FF165K - $61 each
    Back-Loaded horn plans for the 166E
    Goldwood GW8003 - $19 each
    Pioneer B20FU20-51 - $24 each
    Pioneer TS-G1615 - $20 pair (I think this model has changed now to a flashy blue cone/silver whizzer - but it has its following in FR driver use. 92db 35-22Khz)
    That's only scratching the surface, but should get you started. On the Fostex, both models I listed have a 4.5" inch model also, that run about $40 each. Check out the Tang-Band 3" and 4" offerings from partsexpress also. Check out the Aura 3" from madisound.
    Cheers,
    Russ
  • nadams
    nadams Posts: 5,877
    Sid- not sure if you're interested, but I have a pair of Pioneer TS-162 speakers. They're used, but in great shape, and come with the original box/grilles and all that. Specs are as follows:
    6 1/2" Dual-cone
    Max 80w, RMS 20w
    45-18,000Hs, 92dB/W (1m)
    Water-resistant cone
    Strontium magnet
    shallow basket design
    They're yours for the price of shipping. I'll likely never use them again, and am moving in a month or so and am cleaning everything out I don't need. My original use was in a speaker box containing two 12" subs, these two speakers, and two Optimus tweeters. The box sounded good, but the last time I heard it was way before I was into quality sound. I wanted it LOUD, and that box did very well for me. That being said, the speakers can handle power as long as you're not too heavy on them. I would estimate shipping somewhere around $6.50-$7
    nadams
    Ludicrous gibs!
  • gatemplin
    gatemplin Posts: 1,595
    I built a pair of speakers with these. They have a very high quality clear sound, but do not go really loud. When paired with a sub and crossed over high, they are great beginner diy speakers. Do some searches on them, many people have used them at www.diyaudio.com
    Graham
    VR3 Posts: 29,762
    I am think I am going to go with the...
    Fostek FE166E
    Here is what I have figured up basically by looking at the plans Russ sent me...
    7" Wide Internal, 16.5" tall internall, 8" Deep internal
    Woofer Cut out hole, 6"
    Woofer from top of the cabinet (middle of woofer) 4 inches (from internal cabinet)
    Port 3.25" from internal cabinet
    Port depth - 4 - Port Diameter - 2.5
    http://www.madisound.com/ - FE166E
    These will be geared more torwards sound quality than overall volume...
    the driver says 22 watts input, 60 watts music?? i dont understand...?
    Also, thanks for the offer Nadams - I wont have a use for it I dont believe, maybe someone else will want it? Thanks again!
    And thanks for all the suggestions! Very helpful! I am sure my project will change again and again lol
  • nadams
    nadams Posts: 5,877
    NP, Sid. Hope the project works out for you. I'm compiling a list of everything I want to move out of here... expect to see it in the Flea Mkt soon.
    Ludicrous gibs!
  • gidrah
    gidrah Posts: 3,050
    If you can do it in your shop class go ahead and do the back loaded horns. You'll be surprised how good they sound.
    Make it Funky! :)
    VR3 Posts: 29,762
    If I do this...
    What will I need exactly.......to keep this thing away from the lower frequencies?
    And what is the difference in input and music power?
  • RuSsMaN
    Input (continuous), Music (peak).
    Keep bass away? WHY MAN WHY? That's what folded horns and tuned pipes and labyrinths are for man!
    The enclosure loads the bass, not the driver.
    In a ported enlcosure, the driver is loading the bass (taking more of the load, damping), so it will get to moving, but that's OK too. These speakers, done properly (ported), will still sound OUTSTANDING, esp on vocals, jazz, acoustic sets. You just can't crank them up REAL high or you will notice an INSTANT midrange breakup and beaming in the high freq's.
    Build it, even if you just go ported. If you want, buy a pair of the Pioneer / Goldwood that I linked you too, and I'll help you build a quarter wave. Much easier than a back loaded horn, but PHENOMENAL bass results.
    If you want to do a 1/4 wave or labyrinth, let me know. I'll start running numbers on the driver, and I've got plenty of binding posts and damping material I can send you.
    Cheers,
    Russ
    VR3 Posts: 29,762
    Russ convinced me to go with this...
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-045
    And he said he would send me some plans for it using a Labyrinth design........
    So, I am curious to see how this goes and how large/small this thing is...
    Since the FR pioneers costs considerably less, and this uses less parts -- I wouldnt mind buying the MDF just in case...
    Hmm, will keep yall updated
    Thanks Russ for all your help! And thank you everyone else that has thrown out their advice! Maybe this will be the project I do with, simple enough it seems...
  • gidrah
    gidrah Posts: 3,050
    I think you'll be very pleased. I still listen to my 4" full range periscopes once in awhile and I have some other full range speakers that I listen to quite often.
    Make it Funky! :)
    VR3 Posts: 29,762
    Yeah, only experience i have with FR drivers is my TV and some select boomboxes ;)
    So, needless to say...I am interested...
    More or less, I am interested in mostly on how it keeps up with the bass AND the high end at the same time...
    Will the pioneers be able to play louder? And still maintain composure?
  • phoneisbusy
    phoneisbusy Posts: 867
    The Back-Loaded horn plans for the 166E look very interesting/striking as a project. Too bad the super tweeter pricing is a bit beyond my budget. :(
    I'm not very familar with horn and FR speakers. Are they more sensitive to placement then your typical 2 way bass reflex speakers?
    Any idea if they would work well with classical music/opera and some soft rock for a 2 ch bedroom rig setup?
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • gidrah
    gidrah Posts: 3,050
    They would work great with that style of music. They may give up a little in volume on the crescendoes if you're listening too loud. I wouldn't think of them as hard to place, but more along the lines of when you get the placement right with these it's much more apparent than with most BRs.
    I wouldn't worry about the tweeter then. They'll sound great with it and unless you listen to alot of tamborine or piccolo you should be fine. Some Rat Shacks still have close-out horn super tweeters left.
    Make it Funky! :)
  • phoneisbusy
    Thanks gidrah,
    A followup to the placement question then. Can they tolerate being placed close to the wall? There's not a lot of space in the bedroom and having speakers in the middle of the room would be frowned upon by the other occupant.
    regards
    Dave
  • gatemplin
    If you are making your own full range speakers, then wall placement makes things easy. You dont have to do any baffle step compensation like you might have to for speakers placed in the middle of a room. For full range drivers, just throw them in the proper box and you done (maybe a notch filter). I cant comment on horns though.
    Graham
