Calibration
okiepolkie
What calibration DVD would be best to calibrate video and audio? I know the Avia test disk is great. Is the Sound and Vision disk(I believe it is even produced by Ovation like Avia) as good, or do I need to spend the extra to get the Avia? I already have the Radio Shack sound level meter from being a science teacher(great for seeing how loud students can be when you add more and more talking.)
Tschüss
Zach
Zach
Post edited by okiepolkie on
I have the design essentials dvd that I got on ebay for $13 new. I havent tried the other disks but design essentials got the highest review out off all of the disks in a magazine I read. You can set your levels with a dvd with "thx optimized" setup, like star wars, finding nemo & a few others.
Digital Video Essentials.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Maybe revisions are out now, but it seems most every calibration disk except the Avia has at least one issue/ shortcoming that had to be worked around...
At any rate here's a calibration reference threads from "Tour's Vault" that you may find useful...
Speaker System Calibration See Doc Spec's post about mid-way down the page...
And don't forget that there are correction factors you need to apply to your SPL meter readings for low frequencies.More later,
Tour...
Vox Copuli
Yea thats it, thought it didnt sound right when I was typing it
I have the S&V disk and I think it does the job just fine.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
I might try the Avia, just because I know I can find a lot of help if I don't understand something fully. The link to the other thread helped me understand a little more too. Thanks.
Now how much should I pay for the DVD? I don't want to pay the $50 from Crutchfield or Ovation.Tschüss
Zach -
Paid around $30 for mine as I recall. Fell out of one of those internet price comparison search engines... forget which one though.More later,
Tour...
Vox Copuli
DVE has a 10 dB subwoofer calibration encoding error. Don't use it, or compensate for the error."What we do in life echoes in eternity"
SVS -
I have DVE.
What do you mean exactly? How can I compensate the error?
TVs: Samsung S95B 65" QD-OLED (den) and LG C2 42" OLED (office)
Receiver: Denon AVR-X3700H (den) and Denon AVR-X2300W (den)
SACD and DVD-A player: Oppo BDP-83
Mains: Polk RTi8 (den) and Dali Ikon 8 (office)
Center: Polk CSi5 (den) and Polk CSi3 (office)
Surrounds: Polk FXi5 (den) and Velodyne surrounds (office)
Sub: SVS PB-2000 (den) and PCi 16-46 (office) -
I bought my DVE for $15 at my work... I'm sure you should be able to pick one up for a similar price around you.Never kick a fresh **** on a hot day.
More later,
Tour...
Vox Copuli
I'm pretty sure you have to bump your sub reading up 10db's higher than what DVE has you calibrating at.Originally posted by SniperREX
I have DVE.
What do you mean exactly? How can I compensate the error?Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Edited to correct erroneous brain cells and avoid confusion... at least on the part of others...
More later,
Tour...
Vox Copuli
Tour I think you have it backwards. if you calibrate to say 75 db's with DVE your sub will be about 10db's too LOW. If you calibrate all speakers to 75 db's you need to calibrate your sub to around 85 db's.
Here is a quote from Doc's thread at HT forum.So by your test, you would have to calibrate the sub to 88dB on DVE.
Correct.
And realize that 85/82 on Avia is running the sub FLAT at best (with the C-weighted correction factor included), or maybe even a little cool.
Link to Doc's ThreadSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
tryrrthg,
Started to disagree again, but thought it through...
If you believe that the DVE sub cal is 75db, but it's really 88 (or so), then you would end up calibrating to 62 db (or so) relative to the other speakers.
Yup, too cool... Also, too confusing... Buy the Avia...
More later,
Tour...
Vox Copuli
Thx
Too late for AVIA, already shelled out $25 for DVE
Right now I have my receiver HK 7200 at -5 for the sub and the noise sound was already pretty strong. I'm gonna shake the house with the new setting
The DVE subwoofer calibration tone is 10 dB too hot. It relies on the LFE channel vice redirected bass, and the encoders failed to compensate for the fact that all pre/pros automatically boost the LFE channel 10 dB.
So when your subwoofer level is correct, DVE will show it being 10 dB too high.
In addition, the DVE subwoofer signal is extremely broadband (it has strong content from 15-100 Hz). If you have a subwoofer that digs really deep, and you have room gain down low, the calibration error is exacerbated. In this case, DVE ends up being about 13-15 dB too hot when you factor in deep extension and room gain.
This compared to Avia which relies on redirected bass (as opposed to the LFE channel with DVE) and has a sharply-truncated, narrow-bandwidth sub tone that only extends from 40-80 Hz, thus avoiding room gain down deep.
So if you insist on calibrating with DVE, use 75 dB for the main channels, and anywhere from 85-90 dB on the subwoofer tone, depending on your subwoofer's deep extension capabilities and whether or not you have room gain.
Doc"What we do in life echoes in eternity"
SVS -
Calibration Dvds never get the sound the way I like...I rely on my ear no matter how inaccurate someone might say that is...but calibrating my system wont change my hearing...
I need my surrounds higher and my sub a little below normal...this is the sound for me... a calibration dvd will just tell me to adjust otherwise...am i wrong here?
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
Doesn't sound like it to me.Originally posted by Lsi9
...this is the sound for me...More later,
Tour...
Vox Copuli
Doc
Maybe my DVE is different from yours, because it says 40-80hz.
My mains are +8 and +7 and the sub is -3, so the sub is -10 . It should be correct, isn't it?
What the DVD says and what is actually encoded on the disc are two different things. Trust me - we digitally stripped the LFE channel off and analyzed it. It goes from 15 to over 100.My mains are +8 and +7 and the sub is -3, so the sub is -10 . It should be correct, isn't it?
The relative pre/pro levels of your speaker and subwoofer channels are of little value. If you told me what your SPL values are for calibration, then I could tell you if you are close. Oh, and add the subwoofer brand/model too.
SVS -
Radioshack digital meters, C weight and slow.
75db for all speakers except the sub at about 77db right now, before it was at 75db at -5 on the pre/pro.
Polk 505, not corner loaded.
Your subwoofer is probably significantly undercalibrated at 77 dB with DVE (unless your version has been fixed). Try your AVR test tones and see where the sub comes up on those in relation to the other speakers."What we do in life echoes in eternity"
SVS -
Unfortunately my AVR doesn't have a sub test tone
Then borrow Avia from a member.....
Does your subwoofer feel a bit weak, or does it blend well? You can try it at 75 dB speaks and 83-85 dB sub and see what happens. Easy enough to go back if it seems too loud."What we do in life echoes in eternity"
SVS -
I think it's ok, though this is my first sub so I'm not really sure about it.
I'll try that.
I found the Avia test DVD on ebay for $33(shipping included).
http://cgi.ebay.com/ws/eBayISAPI.dl...mMakeTrack=true
My only question before I buy it is whether the DVD is television ratio specific. I've asked a couple of people, but I have not found a definitive answer yet, so I thought I would ask everyone. I haven't emailed the seller yet to find out.
A little ways down the page it says the following:
"Full Screen (Standard) - 1.33:1
- DVD Encoding: All Regions"
The one I see on Ovation's website doesn't specify whether it is for 4:3 or 16:9. I always asumed it was good for both formats.
My television is 4:3, but most of the other people that I will be calibrating for have 16:9 TV's.Tschüss
Zach
