What's in the MM12?
LittleCar_w/12s
Personally, I am wondering more and more about the MM12 series subs. As an owner of the OLD DB12 series (MM12's pre- predecessor), I can't help but to wonder why the design of the new subs seems so faulty.
So many subs on the market will take quite a lot of abuse. I find it rather odd how the mm12 will not. Many report from underpowered to overpowered, there is a consistent chain of smoked coils in these subs. Most other subs I hear of burning a coil are either well-used, deliberately overpowered, or at least rare.
Polk's famous mm65xx line has proven the ability of Polk to produce a worthy and superior mobile-audio market driver. The 65's will take all kinds of abuse and keep on going. The older mm subs, and the DB subs, both old and new, are well built drivers and will, again, take quite some abuse before any eminent death. I, myself have run 350 watts of Square-wave (the worst possible signal) to my old DB12's and they will eat it up with a grin... they're rated for 400 wattsrms, and 350 square (100% duty cycle) is 350w rms... Now I just dont get it when people come up with mm12's that fried running anywhere within 50 watts of their 500 rms rating... not to mention those over.
From what I've seen posted about the MM12's it seems like the most common problem has been coil failure. True to Polk, the mechanical suspension seems to hold up very well. Not many other complaints have been made, some about the AL cone paint chipping a little, some about tinsel-tap, and a few about the grilles not quite handling the x-max.
One can't help but wonder if there is a design issue or a material issue with this. Perhaps a series of these subs were made from faulty coil wire... in which case a serial set would be easy enough to check against. Maybe there was a design issue, and they were designed for much less wattage than prescribed on the final product. Perhaps a peice of machinery is winding the coils a little awry?
What could it be? Maybe our freinds here at Polk can give us some insight? We know they have the capability and intelligence to bring us the top-notch products we desire, and would never label a product incorrectly... Unless the first missprint of the box saying it's a 300wrms sub was the correct figure... Honestly, we Polk users just want to know the honest truth.
___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself.
Post edited by LittleCar_w/12s on
i concur... cept a 350 square is 700 wrms
Man, we're gettin thin on the support these days...
Just remember Polk, the people that use your products are you're best advertisement, especially in the audio markets... It's lookin grim.Originally posted by MacLeod
Forget the Momo sub. If you get a replacement youll just have to break it in for another 5 years and itll just blow again.
Also, <Neo>, a 350 watt square wave is a 100% duty cycle signal, being similar in power to sending out a straight dc signal. Therefore it is also the same as a 350w rms signal equivalent to a sine wave of 495w output.___________________________
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
I also agree! I had my MM12 a total of 2 months before it just went out. No smoke, just stopped working. I've since gone to the (2) MM2124 which sound better and hit lower. I hope the same doesn't happen again. Let me know if you know of any issues with this sub.
yeah, you're right, i misread what you'd postedIt's not good, very fundamentally simply not good. - geolemon
yea...you guys are light weights...ive blown 6
ive probably paid for the damn things again b/c of shipping...
I want nothing more (car audio wise) than for Polk to bring back the old DB12s. They were (and still are for me) perfect.. Polk should have just slapped a momo logo on them and let them be.Testing
Testing
Testing -
So true... Mine work great too... I hope they never blow so I don't have to find any more to replace them... that day is gonna suck.Originally posted by Tymm
Polk: (if you read this at all) Any word on why the MM12 series has had so many problems? We are all wondering here...___________________________
