Monster Biwiring Cable???
Pinktulip7
Pinktulip7 Posts: 249
Too many different types..which one best for RTI 12 speaker's?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
    F1nut Posts: 52,160
    edited September 2004
    Nothing from Monster, IMHO
  • O'Shag
    O'Shag Posts: 76
    Hi Pinktulip,
    For my RT5000 system I'm using QED Silver Anniversary speaker cables. I was using Monster XP, but the QED Silver Anniversary cables are superior in every way, and they match my Polks perfectly well.
    Polk SRT HT System
    Polk CS1000p / FX1000
    Sony KDS-R70XBR2
    Yamaha RX-Z9 Processor
  • danger boy
    danger boy Posts: 15,722
    i've been using the Monster Z2 for a few years now.. nice heavy guage. and make sure you get one that is correctly terminated with the ends you need.. otherwise. it's hell trying to terminate them youself correctly. the cable is very thick.
    I'm not saying this is the best speaker cable out there.. i'm just saying it's what i use and still enjoy the sound of.
    PolkFest 2012, who's going>?
  • Willow
    Willow Posts: 11,310
    I have come to enjoy me kimbers, I think the 8pr's can be used for bi-wiring...but why waste...I mean spend extra money on bi-wiring, just make new jumpers....
  • Pinktulip7
    Don't have any jumper...order one from Polk.
  • Willow
    Pink...make your own from left over speaker cables much batter than the jumpers polk will send you ( no offence polk)
  • Tour2ma
    Tour2ma Posts: 10,177
    pt7,
    Not to muddy the waters further, but consider bi-amping with the 7300 on the highs and the 500 handling the lows.
    As for wire, start with 12 gauge Woods wire or other "stock" wire available at Lowes or Home Depot. Will establish an inexpensive baseline for you to evaluate any "high-wire" purchases you make down the road.
    More later,
    Tour...
    Vox Copuli
  • ezc
    ezc Posts: 426
    edited October 2004
    I have been using Monster Z2 bi wire for over about a year & have been very happy. Monsters Z2 bi wire & M1.4 are the same cable with a different jacket. M seties is cl2 rated & Z is not rated for in wall use. We use the monster master pin ends & just screw the termination you need on the end.
