Rotel RSP-1068 or NAD T163 processor
hamzahsh
I've a budget of $3000 CDN. for a separate Processor. I've done lot of research on both models but don't know which is better. There isn't much info. available for NAD T163 but lot of people love there ROTEL 1068, so I'm leaning towards it.
How many of you own ROTEL processors? and what do you think about the improvement in sound quality compare to my current pre/pro Yamaha RX-V1400 I'm going to notice. Personally I'm very satisfied with my current setup and want to use it for a while. I just need an opinion for my future upgrade.
Do think buying a separate processor is much better than using a receiver as a pre/pro?
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
NAD C272 (2-ch Amp)
Post edited by hamzahsh on
You should see if you can take one home for a demo. That way, you'll find out how much of a difference it'll make.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
I think the general consensus here is that separates are better, even better than very expensive receivers (like Denon).
I can't speak to the Rotel vs. NAD debate, as I don't have either one, but I know I saw a couple of threads on another forum where s/o was having some problems w/ the Rotel unit. Can't remember what the problem was, something w/ bass management I think. I believe the NAD unit has global bass managment, so if you like individualized managment per channel, NAD may not be for you.
I've read superb reviews of the Parasound Halo processor, but that is way out of your price range.
There's a lot of good reviews for the B&K Ref 50 as well.
Good luck in your search.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
Go here for all info on Rotel. These people love their Rotels.
http://www.htguide.com/forum/forumdisplay.php4?f=20Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Since you are in Canada, look at the Anthem AVM30. You might be able to get this in your price range.
