Password Protection
Early B.
Early B. Posts: 7,900
Is there a way in Windows XP or through the use of some type of software where I can password protect specific files or folders? I want to keep personal notes on my computer instead of using a journal.
Thanks.
"God grooves with tubes."
Post edited by RyanC_Masimo on
  • Strong Bad
    Strong Bad Posts: 4,278
    edited September 2004
    Right click on the folder and choose properties. Choose the 2nd tab called Sharing. See the check box called "Make this folder private"? Check that and only you can access it, that is if you are the only one able to log on using your login name and password.
    That should do it for ya.
    The bill is in the mail. ;)
    John
    No excuses!
  • Early B.
    John --
    Thanks for the quick response. Is there a way to do this without using an account password? I have a home computer that is used by everyone in the household, but there's only one account that's not password protected, so everyone has access to it.
  • Joelsbass
    Joelsbass Posts: 637
    basically he want's to hide his **** ;)
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • Pauly
    Pauly Posts: 4,519
    your drive has to be NTFS not FAT before you can add permissions if its not already done. Just an FYI
    Life without music would
