bi wiring
typonegative911
typonegative911 Posts: 39
i want to know the truth does bi wiring make a difference and how do you hook the speakers up this way with regular speaker wire thanks in advance.
Post edited by typonegative911 on
  • danger boy
    danger boy Posts: 15,722
    edited September 2004
    type-O
    dude. you just opened up a can of worms.. but it's cool.
    the debate whether bi-wiring makes a difference is highly debateable. Some folks say yes.. others say it's all hooey.
    I have my fronts and center bi wired... with good Monster Z2 cables. To me.. it's a slightly more open soundstage in the fronts.
    PolkFest 2012, who's going>?
  • dbournival
    dbournival Posts: 131
    Oh No!!! Not again...
    Bi-wiring is like religion and politics...... some believe strongly one way or the other, most are in the middle.
    I have tried Bi-wiring my Center in the past and I recently switched to a single run of 10AWG from Colbalt Cable.
    http://www.cobaltcable.com/
    I think the single run sounds better to me, just use good quality cable. Maybe I should not have said that because of those that believe "cable is cable". You will have those that believe strongly that bi-wiring is better, you will just have to try it for yourself.
    Do you know someone that has a bi-wire cable with bannana plugs? If so, you could easily just borrow it to try it out.
