Is this possible?
Polkitup2
I have have a separate 2 channel stereo and HT reciever setup sharing one set of speakers. I am tired of swapping speaker cables depending on whether I want to watch a movie or listen to 2 channel stereo and do not want to use the Niles DPS-1 amp selector. So I was thinking, can I connect the multi-channel front speaker outputs from my DVD player to the CD input on my two channel stero pre-amp and send the remaining multi-channel outputs to my HT receiver? I know I would have to control volumes separately if I did this. I guess what I'm asking is are the mutli-channel outputs on a DVD player line level signals or are they something else?
Post edited by Polkitup2 on
If your HT receiver has pre-outs, you can just run the front main pre-out to a spare input on your 2 ch. amplifier. Then when you want to use the HT, switch the amplifier to the input that has the front main pre-out connected to it, and set the volume accordingly.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Unfortunately, I don't have the pre-outs on the receiver. That's why I was wondering if the multi-channel outputs from the DVD player could be used instead.
Volume balancing will be a pain, but your AVR's "Tape Out" should be 2 ch.More later,
Tour...
Vox Copuli
