Adapter to connect phono to line level
michael_w
I was just wondering if there is a reasonably inexpensive adapter I could buy to hook up my dads record player to the line level imputs of my ingerated amp. I called radio shack and the guy told me that since both connections are rca it will work with no adapter but I know thats not the case due to voltage differences. Any ideas?
Post edited by michael_w on
go back to radio shack and get a Phono Preamp. They're both RCA yes, but turntables work off of millivolt signals, not volts. They usually go for $20-25. You could also check online for one.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
So this goes inbetween the aux imput and turntable right?
Ratshack Preamp
Thats the one I need right?
Thanks for the quick reply. -
Yes sir, that's what you need and that's the correct connections.
Here is one from parts express. Cost a little more than the RShack one. Probably worth the difference.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=245-035
Alrighty I think I'll try a Radio Shack one.
Madmax ... thanks for the link. It might be worth the difference but after everything it'll probably be about $100 (cdn) which is a little more than I was expecting to pay. I'll give it some thought but it might be a little outta my desired price range.
