Line Drive?
Early B.
Early B. Posts: 7,900
edited September 2004 in Electronics
Been looking at pre-amps to potentially upgrade my Parasound PH/P 850. Ran across the Parasound PLD-1100. Says it's a "line drive" amplifier. What does that mean?
"God grooves with tubes."
Post edited by Early B. on
    VR3 Posts: 29,435
    It means...
    When you turn it on, it delivers a knock out punch
    Honestly dunno....
  • tonyv1
    tonyv1 Posts: 365
    It means that it takes line level inputs (CD, tape decks and tuners)which I believe is 150 mv minimum input. That means that it won't work with a turntable because a phono cartridge only puts out ~ 6 mv or less. The Parasound P/HP has a phono preamp built-in and the PL-1100 doesn't. That's the difference besides the remote on the PL1100.
