Why are Preamp / Processor so $$$?
wrxmy02
Looking over most amp/processor combos you can get a nice
set-up for $600. DD/DTS many inputs and a fair amp to boot.
A stand alone Preamp/Processor [DD/DTS ect] are $1500-$2500.
Are the quality parts "that" much better/expensive? Or is it the custom design that pushes the price up?
I would like to upgrade from a yamaha amp/DD/DTS combo that's 5 yrs old, but I need to see [or hear] what's the value. I do have a ATI 1805 amp. If you upgraded to a new combo or seperates please do tell.
If this is of any help, Yamaha AV-795, ATI 1805 amp, SVS PB2-ISD
"Monolith" sub ,LSI7 front+surround and LSIC center. SACD/DVD audio also on deck.
Front: LSI7
Center: LSIC
Surrounds: LSI7
SVS PB2-ISD SUB [MONOLITH!]
ATI 1805 Amp
Center: LSIC
Surrounds: LSI7
ATI 1805 Amp
Post edited by wrxmy02 on
The difference is HUGE, and well worth the price...
When you get rid of the amp section, and it costs the same - the quality of the parts go WAY up and it definetely shows through. IMO- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
yes it is quality vs quainty. my onkyo put out 110 wpc and so do my adcom 7607 has 125 there is a big differance in the output and quaility of sound even when hooking the adcom up to the onkyo. now addinf a good pre to it realey makes it sing. also a all in 1 will sell more than a pre pro and that also drives up cost.
Most receivers just use a simple chip amp... its cheap, boring, not all that great sounding, etc etc. A real amp is much better.
But all in all, I do agree with the statement of "ouch, that costs a lot!"Brian Knauss
ex-Electrical Engineer for Polk -
i interpreted the question as wether there is a significant difference in just the premp section of a reciver, as opposed to a dedicated preamp. yes, i notice the huge difference in price. we all seem to be on board that amps have better quality sound than the amp section of a reciever. i agree, and the price difference is worth it. but what about the pre/pro section of a reciever, compared to a dedicated preamp with dd and dts. is the quality that much better than just the pre/pro section of a reciever?
p.s., the most reasonably priced pre/pro i've seen new is the outlaw (800-900?), the only thing i've seem cheaper is my promedia for a little over 100.00 (thank god it does the job, along with my icbm) it just seems wierd that there isnt a wider/more diverse price range for av preampsLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
I think it's partially to do with manufacturers knowing you are over a barrel. Sure there are usually better components, but I think it's also because manufacturers realize that if people are willing to pay for separate amps, cabling, rack, etc., they know most people are willing to pay a little more for a better pre/pro.Make it Funky!
you probably have a sound theory there. i'm sure a 1900 dollar pre pro is better than my promedia, just not 19X betterLiving Room 2 Channel -
