Plymouth Voyager
ScruffEOne
When installing 5 1/4 EX352's under the dash plate of my 96' Voyager, I ran into a depth problem in the left stock port. Is there a way around this without cutting? Does Polk manufacture a low-profile 5 1/4 speaker? Any suggestions are very welcome.
More is always better than not enough!
Post edited by ScruffEOne on
see if you can fit a 3/f mdf baffle behind the speakers, that way you can get a little more clearence.Testing
Testing
Testing -
Thanks, I'll give it a try. There isn't much room between the top of the speaker and the dash plate grille.
More is always better than not enough! -
Worked like a charm...Thanks for the advice!!
